coq-club - Re: [Coq-Club] Accessing Class members
  • From: Durward McDonell <Durward.McDonell AT jhuapl.edu>
  • To: <coq-club AT inria.fr>
  • Subject: Re: [Coq-Club] Accessing Class members
  • Date: Wed, 13 Jan 2016 10:30:04 -0500
  • Authentication-results: mail3-smtp-sop.national.inria.fr; spf=None smtp.pra=Durward.McDonell AT jhuapl.edu; spf=Pass smtp.mailfrom=Durward.McDonell AT jhuapl.edu; spf=Pass smtp.helo=postmaster AT piper.jhuapl.edu
  • Ironport-phdr: 9a23:rWuRDBCa74vrOhbsbhhUUyQJP3N1i/DPJgcQr6AfoPdwSP7/rsbcNUDSrc9gkEXOFd2CrakU1ayG7Ou+CCQp2tWojjMrSNR0TRgLiMEbzUQLIfWuLgnFFsPsdDEwB89YVVVorDmROElRH9viNRWJ+iXhpQAbFhi3DwdpPOO9QteU1JTpkbDtsMOCKyxzxxODIppKZC2sqgvQssREyaBDEY0WjiXzn31TZu5NznlpL1/A1zz158O34YIxu38I46FppIZ8VvCudKMhCLdcET4OMmYv5cStuwOVHiWV4X5JfngMjRNSD0Dg5z39WJr1tmOumvdnxyCAMYvTRpwzXzmm649pSALhkCNBOjIkpjKEwvdshb5W9Ury7yd0xJTZNdmY
Thank you for your help. Yes, ZnZ.compare was the right answer,
which makes sense to me now.
On 01/12/2016 11:49 AM, Sosuke MORIGUCHI wrote:
> It looks you cannot see the projection function "compare" (for Ops)
> from your place.
> How about to use "Import ZnZ." before you access or "ZnZ.compare"
> instead of "compare"?
> 2016-01-13 0:01 GMT+09:00 Durward McDonell
> <Durward.McDonell AT jhuapl.edu>:
>> Hello.
>> I am trying to use the ZModulo library, and having some difficulty
>> accessing ops and specs. Here are some relevant bits:
>> In CyclicAxioms.v we have
>> Module ZnZ.
>> Class Ops (t:Type) := MkOps {
>> compare : t -> t -> comparison; (* e.g. *)
>> (* And something similar for Specs. *)
>> End ZnZ.
>> In ZModulo.v we have
>> Section ZModulo.
>> Variable digits : positive.
>> Hypothesis digits_ne_1 : digits <> 1%positive.
>> (* Definitions for everything in ZnZ.Ops and ZnZ.Specs. *)
>> Instance zmod_ops : ZnZ.Ops Z := ZnZ.MkOps (* Here is a list of
>> previous definitions. *).
>> Instance zmod_specs : ZnZ.Specs zmod_ops := ZnZ.MkSpecs (* Here is a
>> list of previous definitions. *).
>> End ZModulo.
>> Module Type PositiveNotOne.
>> Parameter p : positive.
>> Axiom not_one : p <> 1%positive.
>> End PositiveNotOne.
>> Module ZModuloCyclicType (P:PositiveNotOne) <: CyclicType.
>> Definition t := Z.
>> Instance ops : ZnZ.Ops t := zmod_ops P.p.
>> Instance specs : ZnZ.Specs ops := zmod_specs P.not_one.
>> End ZModuloCyclicType.
>> In foo.v, I have put (omitting scopes and imports)
>> Module PNO : PositiveNotOne.
>> Definition p := 3%positive. (* I.e., we want 3-bit numbers with
>> cyclic addition. *)
>> Lemma not_one : p <> 1%positive.
>> Proof.
>> unfold p.
>> discriminate.
>> Qed.
>> End PNO.
>> Module ZMCT := ZModuloCyclicType PNO.
>> But now I cannot access, e.g., ZMCT.ops.compare (or ZMCT.ops.(compare),
>> or (compare ZMCT.ops)).
>> How do I do something interesting with ZMCT?
>> Durward McDonell
>> durward.mcdonell AT jhuapl.edu
>> 240-228-2690 (DC)
>> 443-778-2690 (Balt.)
Durward McDonell
240-228-2690 (DC)
Attachment: smime.p7s
Description: S/MIME Cryptographic Signature
