- From: Clément Pit--Claudel <clement.pit AT gmail.com>
- To: coq-club AT inria.fr
- Subject: Re: [Coq-Club] Proof General has moved to GitHub!
- Date: Tue, 19 Jan 2016 08:25:23 -0500
- Authentication-results: mail3-smtp-sop.national.inria.fr; spf=None smtp.pra=clement.pit AT gmail.com; spf=SoftFail smtp.mailfrom=clement.pit AT gmail.com; spf=None smtp.helo=postmaster AT mout.kundenserver.de
- Ironport-phdr: 9a23:UANoxhZtBDIvW2GEJYagNQ3/LSx+4OfEezUN459isYplN5qZpci/bnLW6fgltlLVR4KTs6sC0LqI9fGxEjdcqb+681k8M7V0HycfjssXmwFySOWkMmbcaMDQUiohAc5ZX0Vk9XzoeWJcGcL5ekGA6ibqtW1aJBzzOEJPK/jvHcaK1oLsh770qsyYOFkArQH+SI0xBS3+lR/WuMgSjNkqAYcK4TyNnEF1ff9Lz3hjP1OZkkW0zM6x+Jl+73YY4Kp5pIYTGZn9Kq8/VPlTCCksG2Ez/szi8xfZHiWV4X5JeWGXlxdOHz/97Q2/G7z1uzb2u+41jCKeMMj7S6xyQTW+x6huQR7sziwAMmhqoynslsVsgfcD81qarBtlztuMbQ==
On 01/19/2016 01:26 AM, John Wiegley wrote:
>>>>>> Jason Gross
>>>>>> <jasongross9 AT gmail.com>
>>>>>> writes:
>> I think there should instead be a MELPA package, but, as I understand it,
>> PG
>> currently needs arcane emacs flags to compile correctly, and melpa doesn't
>> support that (and it's not clear that it should).
> Any chance we could go full ELPA?
I would love that. I had been discussing it with Stefan. The major roadblocks
are:
1. PG needs a bit of cleaning up before it can be packaged (it has its own
autoload generation strategy, it vendors mmm-mode, `require`-ing certain of
its files crashes it unless some other commands are run, etc.)
2. We need to collect paperwork from contributors.
IMHO (1) is much trickier than (2).
Clément.
- [Coq-Club] Proof General has moved to GitHub!, Clément Pit--Claudel, 01/19/2016
- Re: [Coq-Club] Proof General has moved to GitHub!, Gregory Malecha, 01/19/2016
- Re: [Coq-Club] Proof General has moved to GitHub!, Jason Gross, 01/19/2016
- Re: [Coq-Club] Proof General has moved to GitHub!, John Wiegley, 01/19/2016
- Re: [Coq-Club] Proof General has moved to GitHub!, Clément Pit--Claudel, 01/19/2016
- Re: [Coq-Club] Proof General has moved to GitHub!, Stefan Monnier, 01/19/2016
