- To: coq-club AT inria.fr
- Subject: Re: [Coq-Club] Deriving False from bool : Prop?
- Date: Thu, 28 Jan 2016 13:46:50 +0000
- Authentication-results: mail2-smtp-roc.national.inria.fr; spf=None smtp.pra=bob.atkey AT gmail.com; spf=Pass smtp.mailfrom=bob.atkey AT gmail.com; spf=None smtp.helo=postmaster AT mail-wm0-f54.google.com
- Ironport-phdr: 9a23:yGs+qhSfeB64pYAXVIFMjE7xwNpsv+yvbD5Q0YIujvd0So/mwa64ZxaN2/xhgRfzUJnB7Loc0qyN4/+mATBLvMzJmUtBWaIPfidNsd8RkQ0kDZzNImzAB9muURYHGt9fXkRu5XCxPBsdMs//Y1rPvi/6tmZKSV3BPAZ4bt74BpTVx5zukbvipNuLP04V3nKUWvBbElaflU3prM4YgI9veO4a6yDihT92QdlQ3n5iPlmJnhzxtY+a9Z9n9DlM6bp6r5YTGfayQ6NtRrtBST8iLmod5cvxtBCFQxHcyGEbVzA8lRAAKhTG4QCyCp32uG3zqulwyQGVOMT3SfY/XjH0vPQjcwPhlCpSb21xy2rQkMEl1K8=
Hello all,
I believe the model sketched by Thorsten below is essentially the same as the one described for ECC by Zhaohui Luo [1] (Chapter 7), which has an impredicative universe Prop at the bottom of an otherwise predicative hierarchy of universes. Inaccessible cardinals are used to interpret the Type_i universes (see page 146 of the PDF).
[1] http://www.lfcs.inf.ed.ac.uk/reports/90/ECS-LFCS-90-118/ECS-LFCS-90-118.pdf
Bob
On 28/01/16 13:29, Thorsten Altenkirch wrote:
Hi,
I haven’t read Benjamin’s paper, so maybe what I am saying is just a
summary of what he has done. Let me summarize how to prove consistency
of CoC with some extra stuff using omega-sets.
An omega-Set X is a pair |X|:Set and ||- : Nat -> |X| -> Prop s.t. For
all x:|X| there exists a “realiser” n : Nat s.t. n ||-X x. A morphism
between omega-sets X,Y s a function X -> Y and a number k : Nat which is
viewed as the index of a recursive function tracking f, that is for any
m ||-X x we have that {k}m that is the application of the kth
Turingmachine to m terminates with a number n and n ||-Y f(x). It is not
hard to see that omega-Set is cartesian closed and with a bit more work
we can see that we can interpret dependent types and Pi, Sigma etc.
The interesting observation is that we can model an impredicative
universe in omega-Set. This is based on the observation that the partial
equivalence relations (that is relations on the natural numbers that are
symmetric and transitive but not necessarily symmetric) are equivalent
to a the sub model of modest omega-sets. Here a modest omega set is one
where a realiser realises at most one element that is n ||- x and n ||-
y implies x=y. Given a modest w-set we can construct a PER by saying
that mRn iff there exists x:|X| and m ||- x and n ||- x. On the other
hand given a PER R, we construct an omega set whose carrier is Nat/R and
||- is just being an element of the equivalence class. This operations
constitute an equivalence, i.e. There are inverse unto isomorphism. Now
since PER is a set we can define |PROP| = PER and the realiser relation
is trivial (everything realises everything).
Now I don’t think it is difficult to extend this model by universes,
because above PROP it is basically set-theoretic. That is we can embed
sets using the same technique as with PER, I.e. Use the trivial
realisers. Hence inaccessible cardinals in your ambient set-theory give
rise to universes in your type theory.
I used ideas from this model to do my normalisation proof in my ’93 PhD
[1]. Basically I replaced natural numbers by strongly normalising lambda
terms and I required that realizers are closed under candidate-like
conditions.
Cheers,
Thorsten
[1] http://www.cs.nott.ac.uk/~psztxa/publ/phd93.pdf
<cody.roux AT gmail.com
<mailto:cody.roux AT gmail.com>>
Reply-To:
"coq-club AT inria.fr
<mailto:coq-club AT inria.fr>"
<coq-club AT inria.fr
<mailto:coq-club AT inria.fr>>
Date: Wednesday, 27 January 2016 18:31
To:
Thorsten: You'd know best, but I don't really have an intuition about
how to add inaccessibles to the omega-set model. Certainly, this could
look very different from the set theoretic model I know and (somewhat)
love. Maybe there's a super topos-theoretic result that makes this all
easy, but it seems pretty tricky from down in the type-theoretic weeds.
Eddie: Certainly Impredicative Set with excluded middle is not kosher,
because of the Berardi paradox:
https://coq.inria.fr/library/Coq.Logic.Berardi.html
In fact building *any* model of impredicative sets seems to be pretty
subtle, so I'm asking about what is currently known about such non-proof
irrelevant models. A good reference for omega-sets by Phoa can be found
here:
http://www.lfcs.inf.ed.ac.uk/reports/92/ECS-LFCS-92-208/ECS-LFCS-92-208.ps.gz
As a side note, I'm sure you're aware of this, but it might be useful to
remind others of the Barras formalization of IZF in Coq:
http://www.lix.polytechnique.fr/Labo/Bruno.Barras/proofs/sets/index.html
and http://www.lix.polytechnique.fr/Labo/Bruno.Barras/proofs/sets/Ens.html
it's a bit terse, unfortunately.
On Wed, Jan 27, 2016 at 12:47 PM, Eddy Westbrook
<westbrook AT kestrel.edu
<mailto:westbrook AT kestrel.edu>>
wrote:
Hi Thorsten,
I would be very interested to know more about this. Could you please
share a brief description of, or a pointer to, your definition of
omega-sets?
However, as I mentioned in my email, Benjamin Werner did already do
a model using inaccessible cardinals in ZFC (see his “Sets in Types,
Types in Sets” paper). I, at least, would interested in a model that
is formalized in Coq, and that would seem to require it to not use
inaccessible cardinals…?
-Eddy
On Jan 27, 2016, at 9:35 AM, Thorsten Altenkirch
<Thorsten.Altenkirch AT nottingham.ac.uk
<mailto:Thorsten.Altenkirch AT nottingham.ac.uk>>
wrote:
Why can’t we just use omega-Sets? They are certainly a model for
pure CoC and it seems to me that it shouldn’t be too hard to add
universes on top by just using inaccessible cardinals.
Cheers,
Thorsten
Reply-To:
Date: Wednesday, 27 January 2016 17:19
To:
No, afaik, the only proof of consistency of Coq with universes is
Werner's reduction to ZFC with inaccessible cardinals (i.e.,
"types in sets, sets in types").
I am actually working on that problem, and I am in the middle of
formalizing a model of Coq inside Coq. The formalization is
actually inside Coq with informative excluded middle, which, if
successful, would show that informative excluded middle has a high
degree of proof-theoretic strength. However, again, I am still in
the middle of it. I have an unpublished paper that describes some
of my ideas, if you are really interested, but in doing the
formalization I have realized that some points that I missed in
the paper are actually a little more tricky than I had thought.
Eddy
Sent from my iPhone
On Jan 27, 2016, at 6:49 AM, roux cody
wrote:
The consistency proof is quite tricky though, even withoutThis message and any attachment are intended solely for the addressee
universes. Impredicative set is quite brittle, being in
particular anti-classical. On a related note, does anyone know of
a proof of consistency *with* universes? The only proofs that I
know of are Werner's proof of normalization and Altenkirch's
Lambda-set model, which afaik haven't been generalized to systems
with universes.
Thanks,
Cody
On Wed, Jan 27, 2016 at 4:26 AM, Arnaud Spiwack
<aspiwack AT lix.polytechnique.fr
<mailto:aspiwack AT lix.polytechnique.fr>>
wrote:
It's consistent. Set with --impredicative-set is like that.
On 27 January 2016 at 08:44, Jason Gross
<jasongross9 AT gmail.com
<mailto:jasongross9 AT gmail.com>>
wrote:
Is it possible to derive [False] from the assumption that you
have [T : Prop] with [a b : T] and [a <> b]? (On the flip
side, is it possible to show that it's consistent to assume this?)
Thanks,
Jason
and may contain confidential information. If you have received this
message in error, please send it back to me, and immediately delete it.
Please do not use, copy or disclose the information contained in this
message or in any attachment. Any views or opinions expressed by the
author of this email do not necessarily reflect the views of the
University of Nottingham.
This message has been checked for viruses but the contents of an
attachment may still contain software viruses which could damage your
computer system, you are advised to perform your own checks. Email
communications with the University of Nottingham may be monitored as
permitted by UK legislation.
- [Coq-Club] Deriving False from bool : Prop?, Jason Gross, 01/27/2016
- Re: [Coq-Club] Deriving False from bool : Prop?, Arnaud Spiwack, 01/27/2016
- Re: [Coq-Club] Deriving False from bool : Prop?, roux cody, 01/27/2016
- Re: [Coq-Club] Deriving False from bool : Prop?, Eddy Westbrook, 01/27/2016
- Re: [Coq-Club] Deriving False from bool : Prop?, Thorsten Altenkirch, 01/27/2016
- Re: [Coq-Club] Deriving False from bool : Prop?, Thorsten Altenkirch, 01/28/2016
- Re: [Coq-Club] Deriving False from bool : Prop?, Bob Atkey, 01/28/2016
