- To: coq-club AT inria.fr
- Subject: Re: [Coq-Club] Is it possible to rewrite under binders?
- Date: Thu, 28 Jan 2016 11:15:34 -0500
- Authentication-results: mail3-smtp-sop.national.inria.fr; spf=None smtp.pra=jonikelee AT gmail.com; spf=Pass smtp.mailfrom=jonikelee AT gmail.com; spf=None smtp.helo=postmaster AT mail-qk0-f173.google.com
- Ironport-phdr: 9a23:ozT4AxEnxUsJO4myf73ipJ1GYnF86YWxBRYc798ds5kLTJ75pMWwAkXT6L1XgUPTWs2DsrQf27WQ6/yrCTFIyK3CmU5BWaQEbwUCh8QSkl5oK+++Imq/EsTXaTcnFt9JTl5v8iLzG0FUHMHjew+a+SXqvnYsExnyfTB4Ov7yUtaLyZ/niKbqp9aDPk1hv3mUX/BbFF2OtwLft80b08NJC50a7V/3mEZOYPlc3mhyJFiezF7W78a0+4N/oWwL46pyv50IbaKvdKMhCLdcET4OMmYv5cStuwOQYxGI4y4+VWMfjhpBBUDh4RDkU5Ht+n/4sex82ySeMMDeQrU9WDDk5KBuHky7wBwbPiI0pTmEwvd7i7hW9Uqs
On 01/28/2016 08:21 AM, Pierre-Marie Pédrot wrote:
On 28/01/2016 08:40, Guillaume Melquiond wrote:
Now I am not saying that there are no models that invalidate functionalI am actually not quite sure about this stance. Most notably, the
extensionality. What I am saying is that there are no models of coq's
logic that invalidate functional extensionality because of time
complexity of functions (that is impossible). So people should just
refrain from talking about time complexity whenever the topic of
functional extensionality comes around. It is just irrelevant.
Dialectica tranlation gives rise to a model of CIC that allows you
amongst other to count the number of uses of a variable in a function
and thus breaks functional extensionality, but still interprets
convertibility as such (modulo some computational implementation of
multisets). There is an obvious notion of complexity arising from this
feature, so I would not claim that a first-class notion of « complexity
» is not achievable in CIC.
PMP
My example of time complexity wasn't intended to imply anything other than "some arbitrary interesting property" of functions that would make a Coq user not appreciate having functional extensionality forced on them by the logic. Hence, I did not intend to stir up this controversy I didn't even know existed. However, I think we are talking past each other in the following way: by "some arbitrary interesting property" of a function (and time complexity qualifies), I didn't intend to restrict myself to a property that Coq's logic can detect when given the functions to analyze. I was thinking of my own tendency to use Coq to develop OCaml functions via extraction. If the output of extraction from two extensionally-equivalent functions would behave differently in OCaml, then I would prefer that they are not treated within Coq as substitutionally identical.
-- Jonathan
- Re: [Coq-Club] Is it possible to rewrite under binders?, (continued)
- Re: [Coq-Club] Is it possible to rewrite under binders?, Jonathan Leivent, 01/26/2016
- Re: [Coq-Club] Is it possible to rewrite under binders?, Emilio Jesús Gallego Arias, 01/26/2016
- Re: [Coq-Club] Is it possible to rewrite under binders?, Pierre-Yves Strub, 01/27/2016
- Re: [Coq-Club] Is it possible to rewrite under binders?, Thorsten Altenkirch, 01/27/2016
- Re: [Coq-Club] Is it possible to rewrite under binders?, Jonathan Leivent, 01/27/2016
- Re: [Coq-Club] Is it possible to rewrite under binders?, Guillaume Melquiond, 01/27/2016
- Re: [Coq-Club] Is it possible to rewrite under binders?, Guillaume Melquiond, 01/28/2016
- Re: [Coq-Club] Is it possible to rewrite under binders?, Pierre-Marie Pédrot, 01/28/2016
- Re: [Coq-Club] Is it possible to rewrite under binders?, Jonathan Leivent, 01/28/2016
- Re: [Coq-Club] Is it possible to rewrite under binders?, Guillaume Brunerie, 01/28/2016
