coq-club - Re: [Coq-Club] Organization of Coq enhancement requests from UI developers
  • To: coq-club AT inria.fr
  • Subject: Re: [Coq-Club] Organization of Coq enhancement requests from UI developers
  • Date: Fri, 29 Jan 2016 09:23:13 +0100
  • Authentication-results: mail3-smtp-sop.national.inria.fr; spf=None smtp.pra=enrico.tassi AT inria.fr; spf=None smtp.mailfrom=gares AT fettunta.org; spf=None smtp.helo=postmaster AT fettunta.org
  • Ironport-phdr: 9a23:xb4gxBQSUBE2NgcWsoncWeMZp9psv+yvbD5Q0YIujvd0So/mwa64Zx2N2/xhgRfzUJnB7Loc0qyN4/+mATFLuM/Q+Fk5M7VyFDY9wf0MmAIhBMPXQWbaF9XNKxIAIcJZSVV+9Gu6O0UGUOz3ZlnVv2HgpWVKQka3CwN5K6zPF5LIiIzvjqbpq8KVO1gD3WPsKZpJbzyI7izp/vEMhoVjLqtjgjDomVBvP9ps+GVzOFiIlAz97MrjtLRq8iBXpu5zv5UYCfayLOwESulTCy1jOGQo7uXqswPCRE2B/CgySGITxzdOGQnO61nGV4zqs2Ouu+xn2SKde9H/Vqs1cTWk9aZiDhHy3nRUfwUl+X3a35QjxJlQpwis8kRy
On Thu, Jan 28, 2016 at 10:01:54PM -0500, Kenneth Roe wrote:
> 1) parsing support—Input a Coq command or expression and in response,
> Coq returns an xml representation of the parse tree is returned with
> line/column information. (Is this already present)?
Yes. It is available via the CoqIDE XML protocol IIRC. The AST pretty
printer requires some work, possibly it should be rewritten using the modern
ppx technology OCaml provides. Right now it is written by hand, hence
it lags behind (not all AST nodes are supported).
> 3) Extensions to the asynchronous (PIDE) interface to support multiple
> source files. Is this already present?
It is not, and Coq itself can hardly do that. So I'm afraid you'd need
to simulate that on the UI side.
I like your initiative, writing down the requirements of modern IDEs is
a good step forward IMO.
It has not been announced yet, but we are organizing a week long
hackaton (last year was called Coding Sprint) around the end of May or
beginning of June. It would be nice to have all the user interface guys
and the Coq developers in the same room.
Best,
Enrico Tassi
