- To: coq-club AT inria.fr
- Subject: Re: [Coq-Club] Organization of Coq enhancement requests from UI developers
- Date: Sat, 30 Jan 2016 11:56:13 +0100
- Authentication-results: mail3-smtp-sop.national.inria.fr; spf=None smtp.pra=enrico.tassi AT inria.fr; spf=None smtp.mailfrom=gares AT fettunta.org; spf=None smtp.helo=postmaster AT fettunta.org
- Ironport-phdr: 9a23:eGoodh3Hfl8KHOWesmDT+DRfVm0co7zxezQtwd8ZsegVLfad9pjvdHbS+e9qxAeQG96LtLQc26GP4+jJYi8p39WoiDg6aptCVhsI2409vjcLJ4q7M3D9N+PgdCcgHc5PBxdP9nC/NlVJSo6lPwWB6kO74TNaIBjjLw09fr2zQd6NyZznnLnis7ToICx2xxOFKYtoKxu3qQiD/uI3uqBFbpgL9x3Sv3FTcP5Xz247bXianhL7+9vitMU7q3cY6Lod8JtLVry/dKAlR5RZCi4nOiY7/p7Frx7GGCaJ/HoXVS0qmwFTAkCR4RfgX5z29DfzrfF88CicJ8z/C74uD2fxp5x3QQPl3X9UfwUy93va35R9
On Fri, Jan 29, 2016 at 07:08:40PM -0500, CJ Bell wrote:
> Speaking of the CoqIDE XML protocol, I've partially documented it here:
> https://github.com/siegebell/vscoq/blob/master/CoqProtocol.md
Very nice. A simple remark: your description mixes the encoding of
remote function calls with the encoding of their payloads. It may help
to separate the two things. You may also want to link
https://github.com/coq/coq/blob/trunk/ide/interface.mli#L222
For the records, there is also a related document by Emilio. It focuses
on the API the XML protocol is based upon, it is somewhat complementary.
https://github.com/ejgallego/jscoq/blob/master/notes/coq-notes.md
Best,
Enrico Tassi
- [Coq-Club] Organization of Coq enhancement requests from UI developers, Kenneth Roe, 01/29/2016
- Re: [Coq-Club] Organization of Coq enhancement requests from UI developers, Jason Gross, 01/29/2016
- Re: [Coq-Club] Organization of Coq enhancement requests from UI developers, Clément Pit--Claudel, 01/29/2016
- Re: [Coq-Club] Organization of Coq enhancement requests from UI developers, Kenneth Roe, 01/30/2016
- Re: [Coq-Club] Organization of Coq enhancement requests from UI developers, Enrico Tassi, 01/29/2016
- Re: [Coq-Club] Organization of Coq enhancement requests from UI developers, CJ Bell, 01/30/2016
- Re: [Coq-Club] Organization of Coq enhancement requests from UI developers, Enrico Tassi, 01/30/2016
