- To: Coq Club <coq-club AT inria.fr>
- Subject: Re: [Coq-Club] Universes in Modules
- Date: Sat, 30 Jan 2016 22:34:22 -0800
- Authentication-results: mail3-smtp-sop.national.inria.fr; spf=None smtp.pra=gmalecha AT gmail.com; spf=Pass smtp.mailfrom=gmalecha AT gmail.com; spf=None smtp.helo=postmaster AT mail-yk0-f171.google.com
- Ironport-phdr: 9a23:S7mk0xKRRnhYi936gNmcpTZWNBhigK39O0sv0rFitYgULf7xwZ3uMQTl6Ol3ixeRBMOAu60C07qd6f28EUU7or+/81k6OKRWUBEEjchE1ycBO+WiTXPBEfjxciYhF95DXlI2t1uyMExSBdqsLwaK+i760zceF13FOBZvIaytQ8iJ35vxj7D5ocCPKyxzxxODIppKZC2sqgvQssREyaBDEY0WjiXzn31TZu5NznlpL1/A1zz158O34YIxu38I46Fp34d6XK77Z6U1S6BDRHRjajhtpZ6jiR6WZgyWrlAYT29exhFPGk3O6Azwdpb3qCrz8ORnjnq0J8rzGJ8uVDul9bYjbRbshSwHPnZt/2TejsF7jKtzrxeophg5yInRNtLGfMFid7/QKItJDVFKWdxcAmkYWtux
Hi, Jason --
Thanks for the answer. I think this will work for me, it is more verbose than ideal but it will work.
On Sat, Jan 30, 2016 at 1:41 PM, Jason Gross <jasongross9 AT gmail.com> wrote:
Are you asking: "How do I generate fresh (monomorphic?) universe variables every time I mention a particular module type in an argument list?"
I want to make a functor that builds an inductive type (and supporting functions) instantiated at a particular universe.
Universe variables are either global, or local to a definition. (There's a strange intermediate state when you have section-local polymorphic universes, which, if I understand correctly, are considered global while inside the section, but are replaced by definition-local universes when closing the section.) Universe variables can't be local to modules/module types, and I don't think there's any way to get Coq to generate new universes on a Module declaration line, though I may be wrong.The closest I could get is the following. Is this something like what you want?Set Universe Polymorphism.Set Printing Universes.Monomorphic Universe UT.Module Type Uni.Monomorphic Parameter U : Type@{UT}.Axiom U_elim : U -> Type@{UT}.Coercion U_elim : U >-> Sortclass.Global Arguments U_elim / .Global Arguments U / .End Uni.Module U0 <: Uni.Monomorphic Definition U := Type.Definition U_elim : U -> _ := fun x => x.End U0.Module U1 <: Uni.Monomorphic Definition U := Type.Definition U_elim : U -> _ := fun x => x.End U1.Module Option (Import U : Uni) (Import U' : Uni).Inductive option (T : U.U) :=| None| Some (_ : T).Record prod (A : U.U) (B : U'.U) := pair { fst : A ; snd : B }.End Option.Module Option0 := Option U0 U1.On Sat, Jan 30, 2016 at 3:58 PM, Gregory Malecha <gmalecha AT gmail.com> wrote:Hello --I'm wondering if there is a clean way to to make a module type that carries a universe. What I would ideally want to do is something like:Module Type Uni.Universe U.End Uni.Module Option (U : Uni).Inductive option (T : Type@{U.U}) : Type :=| None| Some (_ : T).End.But the universe U is not accessible. My attempt, which I do not think actually works is something like this:Module Type Uni.Universe U.Parameter type : Type@{U}.End Uni.Module Option (U : Uni).Definition U := ltac:(match type of U.type with | ?T => exact T end).Inductive option (t : U) : Type :=| None| Some (_ : T).End Option.As far as I can tell though, the universe [U] seems to be fixed, and does not vary between different instances of the module type.Does anyone know of a way to achieve this?Thanks.--gregory malecha
gregory malecha
- [Coq-Club] Universes in Modules, Gregory Malecha, 01/30/2016
- Re: [Coq-Club] Universes in Modules, Jason Gross, 01/30/2016
- Re: [Coq-Club] Universes in Modules, Gregory Malecha, 01/31/2016
