coq-club - [Coq-Club] Question about fold and, probably, inductive definitions
  • To: "coq-club AT inria.fr" <coq-club AT inria.fr>
  • Subject: [Coq-Club] Question about fold and, probably, inductive definitions
  • Date: Mon, 1 Feb 2016 13:16:31 +0200
  • Authentication-results: mail2-smtp-roc.national.inria.fr; spf=None smtp.pra=ilmars.cirulis AT gmail.com; spf=Pass smtp.mailfrom=ilmars.cirulis AT gmail.com; spf=None smtp.helo=postmaster AT mail-yk0-f182.google.com
  • Ironport-phdr: 9a23:oiL68BcZ1+vouWC0VfgfCs3RlGMj4u6mDksu8pMizoh2WeGdxc68YB7h7PlgxGXEQZ/co6odzbGG7Oa5ASdaud6oizMrTt9lb1c9k8IYnggtUoauKHbQC7rUVRE8B9lIT1R//nu2YgB/Ecf6YEDO8DXptWZBUiv2OQc9HOnpAIma153xjLDtvcSLKF8QzBOGIppMbzyO5T3LsccXhYYwYo0Q8TDu5kVyRuJN2GlzLkiSlRuvru25/Zpk7jgC86l5r50IAu3GePFyRrtBST8iLmod5cvxtBCFQxHFri8XVXxTmR5VCSDE6gv7V9H/qH2pmPB63Xy7OchdV6t8cjW48qNqU1e8iSMCPiQitmrWkNF0jblzrxeophg5yInRNtLGfMFid7/QKItJDVFKWdxcAnRM
What's the difference between 1st and 2nd example? The 2nd isn't accepted.
(* 1 *)
Require Import Utf8 List.
Set Implicit Arguments.
Inductive tree (A: Type) :=
 | leaf
 | root: list (tree A) → tree A.
Fixpoint count (T: tree nat) :=
  match T with
  | leaf _ => 1
  | root l => fold_right (λ x, plus (count x)) O l
  end.
(*2*)
Require Import Utf8.
Inductive list A: nat → Type :=
 | nil: list A 0
 | cons: ∀ n, A → list A n → list A (S n).
 | leaf
 | root: ∀ n, list (tree A) n → tree A.
Fixpoint fold_right A B n (f: B → A → A) (a: A) (L: list B n): A :=
  match L with
  | nil _ => a
  | cons x t => f x (fold_right f a t)
  end.
  match T with
  | leaf _ => 1
  end.
(* Error:
Recursive definition of count is ill-formed.
In environment
count : tree nat → nat
T : tree nat
n : nat
l : list (tree nat) n
x : tree nat
Recursive call to count has principal argument equal to
"x" instead of "l".
Recursive definition is:
"λ T : tree nat,
 match T with
 | leaf _ => 1
 | @root _ n l => fold_right (λ x : tree nat, Nat.add (count x)) 0 l
 end". *)
