- From: Clément Pit--Claudel <clement.pit AT gmail.com>
- To: coq-club AT inria.fr
- Subject: Re: [Coq-Club] Question about fold and, probably, inductive definitions
- Date: Mon, 1 Feb 2016 11:37:58 -0500
- Authentication-results: mail3-smtp-sop.national.inria.fr; spf=None smtp.pra=clement.pit AT gmail.com; spf=SoftFail smtp.mailfrom=clement.pit AT gmail.com; spf=None smtp.helo=postmaster AT mout.kundenserver.de
- Ironport-phdr: 9a23:7Ub8pBdIJZb8ioPycmwZJzSZlGMj4u6mDksu8pMizoh2WeGdxc6+YR7h7PlgxGXEQZ/co6odzbGG7Oa5ACdavN6oizMrTt9lb1c9k8IYnggtUoauKHbQC7rUVRE8B9lIT1R//nu2YgB/Ecf6YEDO8DXptWZBUiv2OQc9HOnpAIma153xjLDtvcSKKF8VzBOGIppMbzyO5T3LsccXhYYwYo0Q8TDu5kVyRuJN2GlzLkiSlRuvru25/Zpk7jgC86l5r50IAu3GePEzSqUdBzA7OUg04tfqvF/NV1ih/HwZB04SEx9FBRTy1BDmG9LatiLnuud5kH2ROcDzQLYoHyyj849kTRbpjGEMMDtvozKfsdB5kK8O+EHpnBd42YOBOIw=
On 02/01/2016 11:25 AM, Cedric Auger wrote:
> I even tend to be a little more "extreme" when I write fixpoints:
> when I write a fixpoint, I almost always try to have the indices of
> the inductive as arguments only (that is almost the minimal set of
> arguments which do not change between recursive calls).
I do not like this style much; it makes the function signature hard to read.
> With this way to write things, it is always obvious on which
> arguments recursion is performed, and minimizes the number of
> arguments to write in recursive calls.
Wouldn't a {struct} annotation do the same?
Clément.
signature.asc
Description: OpenPGP digital signature
- [Coq-Club] Question about fold and, probably, inductive definitions, Ilmārs Cīrulis, 02/01/2016
- Re: [Coq-Club] Question about fold and, probably, inductive definitions, Robbert Krebbers, 02/01/2016
- Re: [Coq-Club] Question about fold and, probably, inductive definitions, Ilmārs Cīrulis, 02/01/2016
- Re: [Coq-Club] Question about fold and, probably, inductive definitions, Cedric Auger, 02/01/2016
- Re: [Coq-Club] Question about fold and, probably, inductive definitions, Clément Pit--Claudel, 02/01/2016
