Re: [Coq-Club] how to prove and evaluate new function definition with this axioms
- To: Pierre Casteran <pierre.casteran AT labri.fr>, "coq-club AT inria.fr" <coq-club AT inria.fr>
- Subject: Re: [Coq-Club] how to prove and evaluate new function definition with this axioms
- Date: Tue, 9 Feb 2016 14:35:03 +0000
- Accept-language: en-US, zh-HK
- Authentication-results: mail2-smtp-roc.national.inria.fr; spf=None smtp.pra=tesleft AT hotmail.com; spf=Pass smtp.mailfrom=tesleft AT hotmail.com; spf=None smtp.helo=postmaster AT COL004-OMC4S11.hotmail.com
- Ironport-phdr: 9a23:X8n6lBCYQ7aHxZlQYFm4UyQJP3N1i/DPJgcQr6AfoPdwSP/5o8bcNUDSrc9gkEXOFd2CrakU1KyN6+u+BCQp2tWojjMrSNR0TRgLiMEbzUQLIfWuLgnFFsPsdDEwB89YVVVorDmROElRH9viNRWJ+iXhpQAbFhi3DwdpPOO9QteU1JTokbvqsMOOKyxzxxODIppKZC2sqgvQssREyaBDEY0WjiXzn31TZu5NznlpL1/A1zz158O34YIxu38I46Fp34d6XK77Z6U1S6BDRHRjajhtpZ6jiR6WdQqC/GERGk4fiQZFGQHDpEXiX5rrqCa8veNmxCSANMveSbk+QzXk4b09DFeigyAecjU97Wv/i8pqjasdrgjr70h0xJeRa4WIPtJ/eLncdJUUXzwScNxWUnlkC4WwfsMqBvAdPOBf593hqkAKoBWiLQmrGObmyzsOjXjzi/5pm989GB3LiVRzV+kFt27Z+ZCsbP8f
I am confusing between definition and fixed point
And between axiom reserved keyword and definition reserved keyword
Can axiom be used in eval ?
If not , what is axiom used for in programming coq
I find a paper that can auto generate fixed point,
I am curious to know whether coq have command to generalize axioms into a function
If not, do this idea exist in application?
If exist, what kind of rules need to apply in order to generalize into a function from axioms.
Hi Martin,
What is really your question?
The code you sent is not even accepted by the Coq system
Please look at the type error message you've certainly got at the
third line; you will understand
that it is impossible for us to answer.
It is important to begin to study Coq with the help of some tutorial.
About your last question about Ring, there is a lot of
documentation about that in the reference manual.
Pierre
Quoting Mandy Martino <tesleft AT hotmail.com>:
> Hi ,
> Require Import Arith.
> Parameter G : Type.
> Axiom reflexive : forall x y z:G, x <= x.
> Axiom symmetric : forall x y z:G, x = y <= y = x.
> Axiom transitive : forall x y z:G, (z = y) * z <= (z = x) * x.
> Regards,
> Martin
Pierre
> Hi ,
> Parameter G : Type.
> Regards,
> Martin
- [Coq-Club] how to prove and evaluate new function definition with this axioms, Mandy Martino, 02/07/2016
- Re: [Coq-Club] how to prove and evaluate new function definition with this axioms, Mandy Martino, 02/07/2016
- Re: [Coq-Club] how to prove and evaluate new function definition with this axioms, Pierre Casteran, 02/07/2016
- Re: [Coq-Club] how to prove and evaluate new function definition with this axioms, Mandy Martino, 02/09/2016
- Re: [Coq-Club] how to prove and evaluate new function definition with this axioms, John Wiegley, 02/09/2016
