- To: coq-club AT inria.fr
- Subject: Re: [Coq-Club] Ssreflect
- Date: Thu, 11 Feb 2016 07:31:57 +0530
- Authentication-results: mail2-smtp-roc.national.inria.fr; spf=None smtp.pra=ranjani141 AT gmail.com; spf=Pass smtp.mailfrom=ranjani141 AT gmail.com; spf=None smtp.helo=postmaster AT mail-io0-f169.google.com
- Ironport-phdr: 9a23:N2oZax2lJDU9L/PWsmDT+DRfVm0co7zxezQtwd8ZsegSKvad9pjvdHbS+e9qxAeQG96LtLQf0KGK7+jJYi8p39WoiDg6aptCVhsI2409vjcLJ4q7M3D9N+PgdCcgHc5PBxdP9nC/NlVJSo6lPwWB6kO74TNaIBjjLw09fr2zQd6NyZ/snLzus7ToICx2xxOFKYtoKxu3qQiD/uI3uqBFbpgL9x3Sv3FTcP5Xz247bXianhL7+9vitMU7q3cY6Lod8JtLVry/dKAlR5RZCi4nOiY7/p7Frx7GGDGG4HkVVGResQBJGAjD5ReyCo34tCnzsOskhHCyMsj/TLRyUjOnufQ4ACT0gTsKYmZquFrcjdZ92fpW
Thank you. I installed coq 8.5. But when I try to compile my file, it gets stuck at 'running..'
How do I know if the compilation was successful?
On Tue, Feb 9, 2016 at 3:18 PM, Enrico Tassi <enrico.tassi AT inria.fr> wrote:
On Tue, Feb 09, 2016 at 07:02:43AM +0530, Ranjani Krishnan wrote:
> I am new to coq. When I tried to do 'Require ssreflect.ssreflect' I am
> getting the compilation error : "File
> E:\Coq\lib\user-contrib\mathcomp/Ssreflect/ssreflect.vo
> has bad magic number. It is corrupted or was compiled with another version
> of
> Coq"
> I am using the coq ide for windows version 8.4pl6. Can someone help me
> solve this?
I guess you installed mathcomp/ssreflect with the installer provided at
http://math-comp.github.io/math-comp/
Unfortunately such installers work only for Coq 8.5.
What I suggest is that you upgrade Coq to 8.5, see the installers here:
https://coq.inria.fr/download
Best,
Enrico Tassi
Thanks,
Ranjani
- [Coq-Club] Ssreflect, Ranjani Krishnan, 02/09/2016
- Re: [Coq-Club] Ssreflect, Enrico Tassi, 02/09/2016
- Re: [Coq-Club] Ssreflect, Ranjani Krishnan, 02/11/2016
- Re: [Coq-Club] Ssreflect, Enrico Tassi, 02/11/2016
- Re: [Coq-Club] Ssreflect, Ranjani Krishnan, 02/13/2016
- Re: [Coq-Club] Ssreflect, Laurent Thery, 02/13/2016
- Re: [Coq-Club] Ssreflect, Ranjani Krishnan, 02/14/2016
