- To: coq-club AT inria.fr
- Subject: Re: [Coq-Club] Doubt about refine
- Date: Wed, 10 Feb 2016 19:50:57 -0500
- Authentication-results: mail2-smtp-roc.national.inria.fr; spf=None smtp.pra=jonikelee AT gmail.com; spf=Pass smtp.mailfrom=jonikelee AT gmail.com; spf=None smtp.helo=postmaster AT mail-qk0-f196.google.com
- Ironport-phdr: 9a23:D9Vu+hK7lhZ/0Qw+5dmcpTZWNBhigK39O0sv0rFitYgUKfXxwZ3uMQTl6Ol3ixeRBMOAu60C0LGd6f6ocFdDyKjCmUhKSIZLWR4BhJdetC0bK+nBN3fGKuX3ZTcxBsVIWQwt1Xi6NU9IBJS2PAWK8TWM5DIfUi/yKRBybrysXNWC0ILsjKvopdX6WEZhunmUWftKNhK4rAHc5IE9oLBJDeIP8CbPuWZCYO9MxGlldhq5lhf44dqsrtY4q3wD86Fpy8kVWqLjOq88ULZwDTI8Mmlz6te4mwPESF6t4X0VTmUflFJsDgnb4RfmFsPztS37ted51SSyMsj/TLRyUjOnufQ4ACT0gTsKYmZquFrcjdZ92fpW
There is another alternative. The type indexes can be omitted in favor of extra equality fields. Doing this enables the use of basic matches in the refine, as in the following rewriting of your example. No convoy patterns are needed. I don't know why this technique isn't mentioned more frequently.
Set Implicit Arguments.
Section Sequence.
Variable E: Set.
Inductive Sequence(n : nat) : Set :=
| SequenceLeaf: E -> E -> n=0 -> Sequence n
| SequenceNode: forall m, Sequence m -> Sequence m -> n = S m -> Sequence n.
Inductive List(n : nat) : Set :=
| ListLeaf: E -> n=0 -> List n
| ListNode: forall m, E -> List m -> n = S m -> List n.
End Sequence.
Inductive Digit :=
| D0
| D1.
Fixpoint get E n (t: Sequence E n) (ds: List Digit n): E.
Proof.
refine(
match t with
| SequenceLeaf e0 e1 e =>
match ds with
| ListLeaf D0 _ => e0
| ListLeaf D1 _ => e1
| @ListNode _ _ y _ _ e2 => _
end
| @SequenceNode _ _ x s0 s1 _ =>
match ds with
| ListLeaf _ e0 => _
| @ListNode _ _ y d ds' _ =>
match d with
| D0 => get E x s0 _
| D1 => get E x s1 _
end
end
end
all:congruence.
Defined.
-- Jonathan
- [Coq-Club] Doubt about refine, Saulo Araujo, 02/07/2016
- Re: [Coq-Club] Doubt about refine, James Wilcox, 02/07/2016
- Re: [Coq-Club] Doubt about refine, Guillaume Melquiond, 02/07/2016
- Re: [Coq-Club] Doubt about refine, Saulo Araujo, 02/07/2016
- Re: [Coq-Club] Doubt about refine, Saulo Araujo, 02/09/2016
- Re: [Coq-Club] Doubt about refine, Cedric Auger, 02/10/2016
- Re: [Coq-Club] Doubt about refine, Saulo Araujo, 02/10/2016
- Re: [Coq-Club] Doubt about refine, Jonathan Leivent, 02/11/2016
- Re: [Coq-Club] Doubt about refine, Saulo Araujo, 02/11/2016
