coq-club - Re: [Coq-Club] Prevent PG from resizing goal/response windows
  • To: coq-club AT inria.fr
  • Subject: Re: [Coq-Club] Prevent PG from resizing goal/response windows
  • Date: Fri, 19 Feb 2016 10:14:21 -0500
  • Authentication-results: mail3-smtp-sop.national.inria.fr; spf=None smtp.pra=sdconsta AT syr.edu; spf=None smtp.mailfrom=sdconsta AT syr.edu; spf=None smtp.helo=postmaster AT smtp1.syr.edu
  • Ironport-phdr: 9a23:OzaisRc7kZnKk14zvr3yy5sflGMj4u6mDksu8pMizoh2WeGdxc65YR7h7PlgxGXEQZ/co6odzbGG7Oa9ASdesN6oizMrTt9lb1c9k8IYnggtUoauKHbQC7rUVRE8B9lIT1R//nu2YgB/Ecf6YEDO8DXptWZBUiv2OQc9HOnpAIma153xjLDtvcCLKFsZzBOGIppMbzyO5T3LsccXhYYwYo0Q8TDu5kVyRuJN2GlzLkiSlRuvru25/Zpk7jgC86l5r50IAu3GePEzSqUdBzA7OUg04tfqvF/NV1ih/HwZB34dlQZUSwPC6grmV531v2OureZ23y+BIcTeVqEuHzmu8vE4G1fTlC4bOmthoynsgctqgfcDrQ==
Clément,
I just tried:
$ brew remove proof-general
$ brew install --HEAD proof-general
which succeeded, and then I launched Aquamacs, which gave a ProofGeneral 4.4pre splash screen. But I'm still witnessing the same behavior with the resizing windows.
Thanks,
~Scott
On Fri, Feb 19, 2016 at 9:56 AM, Clément Pit--Claudel <clement.pit AT gmail.com> wrote:
Also note that on MacOS, brew now supports (thanks Tej!) installing the latest PG with --HEAD.
On 02/19/2016 09:51 AM, Clément Pit--Claudel wrote:
> Hi Scott,
> PG 4.2 is from 2012; can you try reproducing the issue with 4.4pre? https://github.com/ProofGeneral/PG
> Clément.
> On 02/19/2016 09:39 AM, scott constable wrote:
>> Hi All,
>> I've been having some trouble with CoqIDE on OSX, so I decided to give PG a try instead. I followed the directions from Lance Pollard here:
>> http://lancejpollard.github.io/how-to-install-coq-on-a-mac/
>> Everything is working fine so far, except that with every proof step, the goal window grows, and the response window shrinks. I have the proof-three-window-enable option on, which according to the PG manual "also prevents Emacs automatically resizing windows between proof steps." But this doesn't seem to be working properly. Is this a bug? If so, would the problem be with PG or with Aquamacs?
>> What follows is my software platform:
>> OSX 10.11.3
>> Aquamacs 3.2
>> PG 4.2
>> Coq 8.5
>> Thanks in advance,
>> ~Scott Constable
