- From: Clément Pit--Claudel <clement.pit AT gmail.com>
- To: coq-club AT inria.fr
- Subject: Re: [Coq-Club] Prevent PG from resizing goal/response windows
- Date: Fri, 19 Feb 2016 13:10:02 -0500
- Authentication-results: mail3-smtp-sop.national.inria.fr; spf=None smtp.pra=clement.pit AT gmail.com; spf=SoftFail smtp.mailfrom=clement.pit AT gmail.com; spf=None smtp.helo=postmaster AT mout.kundenserver.de
- Ironport-phdr: 9a23:gHZM0hyUJvZoZ+nXCy+O+j09IxM/srCxBDY+r6Qd0e4RIJqq85mqBkHD//Il1AaPBtWEra8cwLOO7ujJYi8p39WoiDg6aptCVhsI2409vjcLJ4q7M3D9N+PgdCcgHc5PBxdP9nC/NlVJSo6lPwWB6kO74TNaIBjjLw09fr2zQd6NyZnvnLnqptX6WEZhunmUWftKNhK4rAHc5IE9oLBJDeIP8CbPuWZCYO9MxGlldhq5lhf44dqsrtY4q3wD86Fpy8kVWqLjOq88ULZwDTI8Mmlz6te4mwPESF6k4voZX2MKpSJJH02AxxXzQ5v8tmOuve5w3SScIYvuTKwcVjGr7qMtQxjt3nRUfwUl+X3a35QjxJlQpwis8kRy
Thanks. In that case, please open a Proof General bug report at
https://github.com/ProofGeneral/PG/issues , with a slightly more detailed
description of the problem. In particular, it would be useful to have an
example of the script that causes this issue, so the devs can try to
reproduce it.
Cheers,
Clément.
On 02/19/2016 10:14 AM, scott constable wrote:
> Clément,
> I just tried:
> $ brew remove proof-general
> $ brew install --HEAD proof-general
> which succeeded, and then I launched Aquamacs, which gave a ProofGeneral
> 4.4pre splash screen. But I'm still witnessing the same behavior with the
> resizing windows.
> Thanks,
> ~Scott
> On Fri, Feb 19, 2016 at 9:56 AM, Clément Pit--Claudel
> <mailto:clement.pit AT gmail.com>>
> wrote:
> Also note that on MacOS, brew now supports (thanks Tej!) installing the
> latest PG with --HEAD.
> On 02/19/2016 09:51 AM, Clément Pit--Claudel wrote:
> > Hi Scott,
> > PG 4.2 is from 2012; can you try reproducing the issue with 4.4pre?
> > Clément.
> > On 02/19/2016 09:39 AM, scott constable wrote:
> >> Hi All,
> >> I've been having some trouble with CoqIDE on OSX, so I decided to
> give PG a try instead. I followed the directions from Lance Pollard here:
> >> http://lancejpollard.github.io/how-to-install-coq-on-a-mac/
> >> Everything is working fine so far, except that with every proof
> step, the goal window grows, and the response window shrinks. I have the
> proof-three-window-enable option on, which according to the PG manual "also
> prevents Emacs automatically resizing windows between proof steps." But
> this doesn't seem to be working properly. Is this a bug? If so, would the
> problem be with PG or with Aquamacs?
> >> What follows is my software platform:
> >> OSX 10.11.3
> >> Aquamacs 3.2
> >> PG 4.2
> >> Coq 8.5
> >> Thanks in advance,
> >> ~Scott Constable
signature.asc
Description: OpenPGP digital signature
- [Coq-Club] Prevent PG from resizing goal/response windows, scott constable, 02/19/2016
- Re: [Coq-Club] Prevent PG from resizing goal/response windows, Clément Pit--Claudel, 02/19/2016
- Re: [Coq-Club] Prevent PG from resizing goal/response windows, scott constable, 02/19/2016
