- From: Robbert Krebbers <mailinglists AT robbertkrebbers.nl>
- To: coq-club AT inria.fr
- Subject: Re: [Coq-Club] Feature Request: Sealed definitions
- Date: Wed, 24 Feb 2016 14:13:29 +0100
- Authentication-results: mail3-smtp-sop.national.inria.fr; spf=None smtp.pra=mailinglists AT robbertkrebbers.nl; spf=None smtp.mailfrom=mailinglists AT robbertkrebbers.nl; spf=None smtp.helo=postmaster AT smtp1.science.ru.nl
- Ironport-phdr: 9a23:KRdckR92JevFMv9uRHKM819IXTAuvvDOBiVQ1KB91uscTK2v8tzYMVDF4r011RmSDdqdtqIP17qempujcFJDyK7JiGoFfp1IWk1NouQttCtkPvS4D1bmJuXhdS0wEZcKflZk+3amLRodQ56mNBXsq3G/pQQfBg/4fVIsYL+lRciP34/rh6ibwN76XUZhvHKFe7R8LRG7/036l/I9ps9cEJs30QbDuXBSeu5blitCLFOXmAvgtI/rpMYwu3cYh/V0/MlZFK7+Yq4QTLpCDT1gPXpmytfssEz5SgGF62EAGkYMnxBCDhLepEX/V5b1sy31sutmxDKyJ8r8R70uRTe44q1hRQXzziEDYW1quFrLg9B92foI6CmqoAZyltbZ
Dear Jeehoon,
Opaque is merely a hint to the kernel and some tactics to avoid unfolding definitions. Many tactics, as well as unification, do not really respect Opaque. For example:
Definition foo := 0.
Opaque foo.
Goal foo = 0.
Fail unfold foo. (* Error: Cannot coerce foo to an evaluable reference. *)
reflexivity. (* succeeds, reflexivity does not care about Opaque *)
Qed.
Best,
Robbert
On 02/24/2016 02:05 PM, Jeehoon Kang wrote:
Did you try Opaque? I am not sure it is what you want, but it controls the
visibility of the definitions.
https://coq.inria.fr/refman/Reference-Manual008.html#hevea_command141
2016. 2. 24. 오후 9:52에 "Ralf Jung"
<jung AT mpi-sws.org>님이
작성:
Hi all,
In order to prevent the Coq unifier from diverging on failing to unify
certain terms, we started sealing some of our definitions with modules.
This usually looks roughly as follows:
Definition heap_mapsto_def `{heapG Σ} (l : loc) (v: val) : iPropGheap_lang Σ :=
auth_own heap_name {[ l := Excl v ]}.heap_lang Σ.
(* Perform sealing *)
Module Type HeapMapstoSig.
Parameter heap_mapsto : ∀ `{heapG Σ} (l : loc) (v: val), iPropG
Axiom heap_mapsto_eq : @heap_mapsto = @heap_mapsto_def.
End HeapMapstoSig.
Module Export HeapMapsto : HeapMapstoSig.
Definition heap_mapsto := @heap_mapsto_def.
Definition heap_mapsto_eq := Logic.eq_refl (@heap_mapsto).
End HeapMapsto.
We copied this trick from ssreflect. I would not be surprised to hear
that other larger developments are using something similar.
So I wonder, would it be worth adding a feature to Coq where I could
write something like
Sealed Definition heap_mapsto `{heapG Σ} (l : loc) (v: val):
iPropG heap_lang Σ :=
and it would automatically add "heap_mapsto" of appropriate type, make
it as opaque as "Qed."-Lemmas (or as opaque as fields sealed via a
signature, I am not sure if there is any difference), and add a term
"heap_mapsto_eq" or "heap_mapsto_def" that proves that "heap_mapsto" is
equal to its definition?
That would significantly reduce the syntactic overhead and redundancy
associated with the trick that we have to pull off now, to get Coq to
behave. As a bonus, it should work within sections.
Kind regards,
Ralf
- [Coq-Club] Feature Request: Sealed definitions, Ralf Jung, 02/24/2016
- Re: [Coq-Club] Feature Request: Sealed definitions, Jeehoon Kang, 02/24/2016
- Re: [Coq-Club] Feature Request: Sealed definitions, Robbert Krebbers, 02/24/2016
- Re: [Coq-Club] Feature Request: Sealed definitions, Jacques-Henri Jourdan, 02/24/2016
- Re: [Coq-Club] Feature Request: Sealed definitions, Ralf Jung, 02/24/2016
- Re: [Coq-Club] Feature Request: Sealed definitions, Arnaud Spiwack, 02/24/2016
- Re: [Coq-Club] Feature Request: Sealed definitions, Robbert Krebbers, 02/25/2016
- Re: [Coq-Club] Feature Request: Sealed definitions, Arnaud Spiwack, 02/25/2016
