- From: Robbert Krebbers <mailinglists AT robbertkrebbers.nl>
- To: coq-club AT inria.fr
- Subject: Re: [Coq-Club] Feature Request: Sealed definitions
- Date: Thu, 25 Feb 2016 10:09:19 +0100
- Authentication-results: mail3-smtp-sop.national.inria.fr; spf=None smtp.pra=mailinglists AT robbertkrebbers.nl; spf=None smtp.mailfrom=mailinglists AT robbertkrebbers.nl; spf=None smtp.helo=postmaster AT smtp1.science.ru.nl
- Ironport-phdr: 9a23:q8d0ox3rXhNvj75FsmDT+DRfVm0co7zxezQtwd8ZsegTK/ad9pjvdHbS+e9qxAeQG96LtLQa06GO6ujJYi8p39WoiDg6aptCVhsI2409vjcLJ4q7M3D9N+PgdCcgHc5PBxdP9nC/NlVJSo6lPwWB6kO74TNaIBjjLw09fr2zQd6NyZrvnLjrs7ToICx2xxOFKYtoKxu3qQiD/uI3uqBFbpgL9x3Sv3FTcP5Xz247bXianhL7+9vitMU7q3cY6Lod8JtLVry/dKAlR5RZCi4nOiY7/p7Frx7GGDGI7HERSHlesQBFCQLI9gqyCpL4sy/7sOV52TKGJuXsSro+VC6+7L1mQhXlkjxBMTpvozKfsdB5kK8O+EHpnBd42YOBOIw=
It would be nice to add support for Ralf's wish to the Derive mechanism. I have opened https://coq.inria.fr/bugs/show_bug.cgi?id=4594 for this wish.
On 02/25/2016 07:14 AM, Arnaud Spiwack wrote:
Hi Robbert,
Indeed. I retract my implied claim that it may have been used to save a
few keystrokes.
On 25 February 2016 at 00:29, Robbert Krebbers
<mailto:mailinglists AT robbertkrebbers.nl>>
wrote:
Hi Arnaud,
For Ralf's purpose the generated term should be Opaque. As far as I
see, one can only control the opacity of the equality lemma. So, given:
Derive f SuchThat (f = λ x : nat, 10) As foo.
One can control whether foo is Opaque by ending the proof with
Qed/Defined, but not whether f is Opaque.
Robbert
On 02/24/2016 09:15 PM, Arnaud Spiwack wrote:
See also :
https://coq.inria.fr/distrib/current/refman/Reference-Manual033.html#hevea_command305
(syntax subject to changes by the time of next release)
On 24 February 2016 at 14:57, Jacques-Henri Jourdan
<jacques-henri.jourdan AT inria.fr
<mailto:jacques-henri.jourdan AT inria.fr>
<mailto:jacques-henri.jourdan AT inria.fr>>>
wrote:
Le 24/02/2016 14:51, Ralf Jung a écrit :
> Hi,
>> Oh, but you also want the equality lemma.
> Right :)
>> Then you can do something like:
>> Definition x : nat := 1.
>> Definition x_aux : { x':_ & x' = x }.
>> exact (existT _ _ eq_refl). Qed.
>> Definition x_sealed := projT1 x_aux.
>> Definition x_sealed_eq : x_sealed = x := projT2 x_aux.
>> Which is, I admit, not ideal from a syntactic point of
view. However,
>> note that the type and definition of x appear only once.
> Thanks, this indeed looks nicer than using modules!
> Unfortunately, if the type of x is more complicated, this
loses all the
> information about implicit arguments: If some arguments
of "x" were made
> implicit by putting them in "{...}", these are all
explicit for
> x_sealed. So the type has to be repeated, or at least the
implicitness
> information has to be declared again with Arguments.
Well, you don't really need x, so you don't need to give this
information twice. But yes, you have to repeat the
information about
implicitness of arguments.
> Kind regards,
> Ralf
- [Coq-Club] Feature Request: Sealed definitions, Ralf Jung, 02/24/2016
- Re: [Coq-Club] Feature Request: Sealed definitions, Jeehoon Kang, 02/24/2016
- Re: [Coq-Club] Feature Request: Sealed definitions, Robbert Krebbers, 02/24/2016
- Re: [Coq-Club] Feature Request: Sealed definitions, Jacques-Henri Jourdan, 02/24/2016
- Re: [Coq-Club] Feature Request: Sealed definitions, Ralf Jung, 02/24/2016
- Re: [Coq-Club] Feature Request: Sealed definitions, Arnaud Spiwack, 02/24/2016
- Re: [Coq-Club] Feature Request: Sealed definitions, Robbert Krebbers, 02/25/2016
- Re: [Coq-Club] Feature Request: Sealed definitions, Arnaud Spiwack, 02/25/2016
