- From: Julian Michael <julianjohnmichael AT gmail.com>
- To: coq-club AT inria.fr
- Subject: Re: [Coq-Club] constructive proof of (P1 <-> ~ P2) <-> (~ P1 <-> P2)
- Date: Thu, 25 Feb 2016 09:39:26 -0800
- Authentication-results: mail2-smtp-roc.national.inria.fr; spf=None smtp.pra=julianjohnmichael AT gmail.com; spf=Pass smtp.mailfrom=julianjohnmichael AT gmail.com; spf=None smtp.helo=postmaster AT mail-pf0-f171.google.com
- Ironport-phdr: 9a23:98YLdxUAqejgvtBlqRpKh92PUULV8LGtZVwlr6E/grcLSJyIuqrYZhCCt8tkgFKBZ4jH8fUM07OQ6PC/HzJZqsvR+Fk5M7VyFDY9wf0MmAIhBMPXQWbaF9XNKxIAIcJZSVV+9Gu6O0UGUOz3ZlnVv2HgpWVKQka3CwN5K6zPF5LIiIzvjqbpq8KVPVwD2Wr1SIgxBSv1hD2ZjtMRj4pmJ/R54TryiVwMRd5rw3h1L0mYhRf265T41pdi9yNNp6BprJYYAu2pN5g/GLdfFXEtN30/zMztrxjKCwWVtVUGVWBDsAdMAgHDpDT7VZf4vy+y4uhg3CiTO8/xTbYxWD+i5qpvYBDtgSYDcTU+9TeE2YRLkKtHrUf59FREyInObdTNOQ==
whoops, Robbert beat me to it :) yup, generally to verify that a proposition
isn't intuitionistically provable, you can reduce it to LEM, WEM (~p \/ ~~p),
or the law of double negation (~~p -> p); the latter two of which are
equivalent to LEM when taken together. Also, if it's classically provable and
begins with a negation, then it's intuitionistically provable (by Glivenko's
theorem). But these are just tools for propositional formulas.
> On Feb 25, 2016, at 9:28 AM, Robbert Krebbers
> <mailinglists AT robbertkrebbers.nl>
> wrote:
>> On 02/25/2016 05:52 PM, Stefan Ciobaca wrote:
>> I'm wondering if the following is provable constructively:
>> forall (P1 P2 : Prop),
>> (P1 <-> ~ P2) <-> (~ P1 <-> P2).
> No, from this you can prove the classical "double negation" axiom:
> Goal
> (forall (P1 P2 : Prop), (P1 <-> ~ P2) <-> (~ P1 <-> P2)) ->
> forall (P : Prop), ~~P -> P.
> Proof. intros ax P HP; now apply (ax P (~P)). Qed.
> This is done by taking (P1:=P) and (P2:=~P), so this gives:
> (P <-> ~~P) <-> (~ P <-> ~P).
> The RHS is trivial, and the LHS is double negation. Qed :).
> Best,
> Robbert
- [Coq-Club] constructive proof of (P1 <-> ~ P2) <-> (~ P1 <-> P2), Stefan Ciobaca, 02/25/2016
- Re: [Coq-Club] constructive proof of (P1 <-> ~ P2) <-> (~ P1 <-> P2), Benoît Viguier, 02/25/2016
- Re: [Coq-Club] constructive proof of (P1 <-> ~ P2) <-> (~ P1 <-> P2), Jonathan Leivent, 02/25/2016
- Re: [Coq-Club] constructive proof of (P1 <-> ~ P2) <-> (~ P1 <-> P2), Julian Michael, 02/25/2016
- Re: [Coq-Club] constructive proof of (P1 <-> ~ P2) <-> (~ P1 <-> P2), Robbert Krebbers, 02/25/2016
- Re: [Coq-Club] constructive proof of (P1 <-> ~ P2) <-> (~ P1 <-> P2), Ralf Jung, 02/25/2016
- Re: [Coq-Club] constructive proof of (P1 <-> ~ P2) <-> (~ P1 <-> P2), Michel Levy, 02/25/2016
