- From: Abhishek Anand <abhishek.anand.iitg AT gmail.com>
- To: coq-club <coq-club AT inria.fr>
- Subject: Re: [Coq-Club] Lean Theorem Prover
- Date: Thu, 25 Feb 2016 17:46:05 -0500
- Authentication-results: mail2-smtp-roc.national.inria.fr; spf=None smtp.pra=abhishek.anand.iitg AT gmail.com; spf=Pass smtp.mailfrom=abhishek.anand.iitg AT gmail.com; spf=None smtp.helo=postmaster AT mail-yk0-f176.google.com
- Ironport-phdr: 9a23:Z/ZN1BbfTC4/sQAuC7+fkZz/LSx+4OfEezUN459isYplN5qZpcmybnLW6fgltlLVR4KTs6sC0LqJ9f66EjRcqb+681k8M7V0HycfjssXmwFySOWkMmbcaMDQUiohAc5ZX0Vk9XzoeWJcGcL5ekGA6ibqtW1aJBzzOEJPK/jvHcaK1oLsh7/0pceYO1kArQH+SI0xBS3+lR/WuMgSjNkqAYcK4TyNnEF1ff9Lz3hjP1OZkkW0zM6x+Jl+73YY4Kp5pIYTGZn9Kq8/VPlTCCksezQ+49Suvh3eRyOO4GEdWyMYiEwbLRLC6UTTVJfwqSv3taJU3iCcMYWiRLo0WC+i4qQtQRnhjitBNj8l/0nYj8VxiORQpxf39E83+JLdfIzAbKk2RajaZ95PHWc=
MathClasses has something similar, which I like a lot:
-- Abhishek
http://www.cs.cornell.edu/~aa755/On Thu, Feb 25, 2016 at 5:39 PM, Daniel Schepler <dschepler AT gmail.com> wrote:
On Wed, Feb 24, 2016 at 4:17 PM, Saulo Araujo <saulo2 AT gmail.com> wrote:
> Hi,
> I recently discovered the Lean Theorem Prover
> (https://leanprover.github.io/about/). I did some toy experiments with it
> and and, at least in this first contact, it seemed similar to Coq. I am
> curious about how the Coq community sees Lean. Does it see Lean as
> "competitor" of Coq? Is it possible for Coq to bridge the gap betweem
> interactive and automated theorem proving like Lean aims to do?
One thing I did notice in my quick browse through the tutorial: its
standard library includes a typeclass for decision procedures for
propositions (though I'd call it Decision instead of decidable as Lean
does, as the last suggests the proposition (P \/ ~P) rather than
something with extractable information). It also includes a notation
for defining a proof by inferring a decision procedure and then
running it.
This is something I've thought of proposing as an addition to the Coq
standard library at various times - and I might even have mentioned
some elements of my thinking in some previous messages to the list.
So, the basic outline would be something like:
Class Decision (P:Prop) : Set :=
decide : {P} + {~P}.
Arguments decide P [Decision].
Instance true_dec : Decision True := left _ I.
Instance and_dec {P Q:Prop}
`{!Decision P} `{!Decision Q} : Decision (P /\ Q) := ...
Instance bounded_nat_dec {P : nat -> Prop}
`{!forall m:nat, Decision (P m)}
(n : nat) : Decision (forall m:nat, m < n -> P m) :=
fix ...
Instance Forall_dec {A:Type} {P : A -> Type}
`{!forall x:A, Decision (P x)}
(l : list A) : Decision (Forall P l) :=
fix ...
Ltac decide := (* untested *)
match goal with
|- ?P =>
let dec := hnf (decide P) in
match dec with
| left _ ?pf => exact pf
| right _ _ => error 2 "statement is false"
| _ => error 2 "could not evaluate decision procedure"
end
end.
Notation decision_pf := ltac:(decide).
Example my_max (m n:nat) : nat :=
if decide (m <= n) then n else m.
Maybe it could also include some framework for enumerating all
elements of finite types, which would be useful for things like
Definition bor_assoc (x y z:bool) :
bor x (bor y z) = bor (bor x y) z := decision_pf.
Daniel Schepler
- RE: [Coq-Club] Lean Theorem Prover, (continued)
- RE: [Coq-Club] Lean Theorem Prover, Soegtrop, Michael, 02/25/2016
- Re: [Coq-Club] Lean Theorem Prover, Freek Wiedijk, 02/25/2016
- Re: [Coq-Club] Lean Theorem Prover, Théo Zimmermann, 02/25/2016
- Re: [Coq-Club] Lean Theorem Prover, Bas Spitters, 02/25/2016
- Re: [Coq-Club] Lean Theorem Prover, roux cody, 02/25/2016
- Re: [Coq-Club] Lean Theorem Prover, Clément Pit--Claudel, 02/25/2016
- Re: [Coq-Club] Lean Theorem Prover, Jonathan Leivent, 02/25/2016
- Re: [Coq-Club] Lean Theorem Prover, John Wiegley, 02/25/2016
- Re: [Coq-Club] Lean Theorem Prover, Daniel Schepler, 02/25/2016
- Re: [Coq-Club] Lean Theorem Prover, Abhishek Anand, 02/25/2016
- Re: [Coq-Club] Lean Theorem Prover, Daniel Schepler, 02/26/2016
- Re: [Coq-Club] Lean Theorem Prover, roux cody, 02/26/2016
- Re: [Coq-Club] Lean Theorem Prover, Jonathan Leivent, 02/26/2016
- Re: [Coq-Club] Lean Theorem Prover, Arnaud Spiwack, 02/26/2016
- Re: [Coq-Club] Lean Theorem Prover, Clément Pit--Claudel, 02/26/2016
- Re: [Coq-Club] Lean Theorem Prover, Benjamin C. Pierce, 02/26/2016
- RE: [Coq-Club] Lean Theorem Prover, Soegtrop, Michael, 02/26/2016
- RE: [Coq-Club] Lean Theorem Prover, Makarius, 02/26/2016
