- To: "coq-club AT inria.fr" <coq-club AT inria.fr>
- Subject: RE: [Coq-Club] Lean Theorem Prover
- Date: Fri, 26 Feb 2016 19:16:54 +0100 (CET)
- Authentication-results: mail3-smtp-sop.national.inria.fr; spf=None smtp.pra=makarius AT sketis.net; spf=None smtp.mailfrom=makarius AT sketis.net; spf=None smtp.helo=postmaster AT mail-out1.informatik.tu-muenchen.de
- Ironport-phdr: 9a23:EkLb9hR/QxKJxypyM7r9fEHy6dpsv+yvbD5Q0YIujvd0So/mwa64YReN2/xhgRfzUJnB7Loc0qyN4/+mBzdLsMbJmUtBWaIPfidNsd8RkQ0kDZzNImzAB9muURYHGt9fXkRu5XCxPBsdMs//Y1rPvi/6tmZKSV3BPAZ4bt74BpTVx5zukbvipNuNOE4Z1HKUWvBbElaflU3prM4YgI9veO4a6yDihT92QdlQ3n5iPlmJnhzxtY+a9Z9n9DlM6bp6r5YTGfayQ6NtB7dfFXEtN30/zMztrxjKCwWVrDNIWWIP1xFMHgLt7RfgX563vDGs5cRn3yzPGMT1RKo1RC/qu6JiSxbyiTocHyU6/X3WkYp2gb4N80HpnAB234OBONLdD/F5ZK6IJd4=
On Fri, 26 Feb 2016, Soegtrop, Michael wrote:
1.) Using Unicode notations in the HTML version but ASCII in the IDE is
as confusing as finding the shortcuts for the right symbols
2.) Most people read more than they write, so it makes sense to optimize
for readability – and the Unicode symbols are more readable
3.) The shortcuts for the Unicode symbols can be mentioned in IDE menus
at a prominent place
I fully agree that high-end proof assistants should support proper mathematical symbols without the user having to think about it. I disagree that such a blissful situation can be equated with "Unicode". Unicode is a rather big standard with many sub-standards, and it requires years and decades to make it really work for a particular task.
About 8 years ago, I set out to make mathematical symbols "just work" for the forthcoming Prover IDE of Isabelle -- uniformly on all platforms. It required several years to get there, and every year I learned new aspects of Unicode that I could not imagine before. In the current release of Isabelle2016 (February 2016) this is mostly routine, and we have again eliminated a lot of old ASCII replacement syntax. Interestingly, that release also parts with official Unicode in various ways, e.g. see "more arrow symbols" announced here
http://isabelle.in.tum.de/dist/Isabelle2016/doc/NEWS.html
Hopefully you see there arrows of length 3 and 4, taken from a server-side font that is also used in the IDE. Length 1 and 2 are defined by the Unicode standard and are in their usual place. Note that in standard Unicode fonts, length 2 arrows can already be a problem, and lead to disappointing white or black boxes.
Regarding your portability concerns:
· On Windows non-Unicode is dead. The last non Unicode Version was Windows ME (Millennium Edition) which I don’t think is used any more. Even its successor Windows XP is out of maintenance since a while and XP does support Unicode (always – there are no XP systems which don’t support it). Here is a link to OS usage statistics: https://en.wikipedia.org/wiki/Usage_share_of_operating_systems.
· I did a quick search on google for Unicode issues with Linux/Debian/Ubuntu/Fedora/Mint. The first 20 articles I found where all 2009 or older. So I think issues are solved since then, since google doesn’t tend to prefer old articles.
· I would think Mac with its DTP background was pretty much always Unicode.
All these platforms pretend to support Unicode for some decades, but it is still possible to get into problems. It is not something that just works by default and can be counted on.
With some care, it is possible to turn Unicode into some use. I recommend to read the relevant documentation:
http://isabelle.in.tum.de/dist/Isabelle2016/doc/jedit.pdf
http://isabelle.in.tum.de/dist/Isabelle2016/doc/system.pdf
http://isabelle.in.tum.de/dist/Isabelle2016/doc/isar-ref.pdf
and search for "Isabelle symbols". The phrase "Unicode" is hardly ever used, because it is of little relevance.
I have pointed this out to various Coq people more than once, and this is just an opportunity to make a broadcast.
Makarius
- Re: [Coq-Club] Lean Theorem Prover, (continued)
- Re: [Coq-Club] Lean Theorem Prover, Daniel Schepler, 02/25/2016
- Re: [Coq-Club] Lean Theorem Prover, Abhishek Anand, 02/25/2016
- Re: [Coq-Club] Lean Theorem Prover, Daniel Schepler, 02/26/2016
- Re: [Coq-Club] Lean Theorem Prover, roux cody, 02/26/2016
- Re: [Coq-Club] Lean Theorem Prover, Jonathan Leivent, 02/26/2016
- Re: [Coq-Club] Lean Theorem Prover, Arnaud Spiwack, 02/26/2016
- Re: [Coq-Club] Lean Theorem Prover, Clément Pit--Claudel, 02/26/2016
- Re: [Coq-Club] Lean Theorem Prover, Benjamin C. Pierce, 02/26/2016
- RE: [Coq-Club] Lean Theorem Prover, Soegtrop, Michael, 02/26/2016
- RE: [Coq-Club] Lean Theorem Prover, Makarius, 02/26/2016
- Re: [Coq-Club] Lean Theorem Prover, Makarius, 02/26/2016
- Re: [Coq-Club] Lean Theorem Prover, Clément Pit--Claudel, 02/27/2016
- Re: [Coq-Club] Lean Theorem Prover, Makarius, 02/27/2016
- Re: [Coq-Club] Lean Theorem Prover, Enrico Tassi, 02/27/2016
- RE: [Coq-Club] Lean Theorem Prover, Soegtrop, Michael, 02/29/2016
- Re: [Coq-Club] Lean Theorem Prover, Saulo Araujo, 02/27/2016
