- From: Frédéric Blanqui <frederic.blanqui AT inria.fr>
- To: coq-club AT inria.fr
- Subject: Re: [Coq-Club] Is Coq SN ?
- Date: Mon, 29 Feb 2016 12:58:04 +0100
PS. His PhD is available here:
https://tel.archives-ouvertes.fr/tel-00196524 . Le 29/02/2016 12:33, Frédéric Blanqui a
écrit :
Hello.Yes, he did. But he considered only 1 or 2 universes. Frédéric. Neither did I, in my ’93 PhD
http://www.cs.nott.ac.uk/~psztxa/publ/phd93.pdf
but I still think this is the simplest (and first) proof of
SN for CoC with large eliminations – hence I would be grateful
if it doesn’t get completely ignored.
A short summary is given in
http://www.cs.nott.ac.uk/~psztxa/publ/types94.pdf
Cheers,
Thorsten
Reply-To: "coq-club AT inria.fr" <coq-club AT inria.fr> Date: Monday, 29 February 2016 02:21 To: "coq-club AT inria.fr" <coq-club AT inria.fr> Cc: "Luo, Zhaohui" <Zhaohui.Luo AT rhul.ac.uk> Subject: Re: [Coq-Club] Is Coq SN ? Dear all,
In his PhD thesis in 1994, Goguen has studied the meta-theory of UTT (SN, CR, SR, ...) which is essentially CoC + inductive types + universes (ie, a subset of the current Coq system pCIC after its universe Set became predicative.)
Best regards,
Zhaohui From: coq-club-request AT inria.fr
<coq-club-request AT inria.fr>
on behalf of roux cody <cody.roux AT gmail.com>
Sent: 28 February 2016 20:57 To: coq-club AT inria.fr Subject: Re: [Coq-Club] Is Coq SN ? The SN of CIC + universes is
something of a nasty open question at
the moment. With recursors instead of
fixpoint and no co-induction, it's
believed to be indeed strongly
normalizing, with Benjamin Werner's PhD
serving as reference for the CIC without
universes and Luo's thesis for CoC with
universes.
There is no "smoking gun" that seems to
jeopardize consistency, but a complete
write up would be nice.I think part of the issue is that the
theory for strong normalization proofs are
really not streamlined, which means each
individual proof has to do a lot of setup
work, which is really discouraging. In
particular, there seems to be some
resilience to using the "usual"
realizability semantics interpretation.
There's some work by Hyland, Ong and Ritter
on how to fix this, but it hasn't been
pushed all the way through, as far as I
know.
http://citeseerx.ist.psu.edu/viewdoc/download?doi=10.1.1.45.6979&rep=rep1&type=pdf http://www.cse.chalmers.se/~abela/talkIHP14.pdf https://gist.github.com/puffnfresh/8960574 Best,
Cody
This email has been sent from a virus-free computer protected by Avast. www.avast.com On Sun, Feb 28, 2016 at
1:43 PM, Abhishek Anand <abhishek.anand.iitg AT gmail.com>
wrote:
However,
Coq's implementation (if no bugs)
should be weakly normalizing,
which is usually enough for consistency. I thought that for consistency we
also need type preservation (along
with strong/weak normalization).
Coq seems to not have type
preservation, as shown in the last 2
slides (25 and 26) of
https://coq.inria.fr/files/coq5-slides-sacchini.pdf
I just reproduced the above
described problem using Coq 8.5:
Set Implicit Arguments.
CoInductive Inf :=
S : Inf -> Inf.
CoFixpoint infinity : Inf :=S (
infinity).
(** This innocuous looking
function
actually causes an unfolding
of cofix *)
Definition unfold (x : Inf) : Inf
match x with
| S y => S y
end.
Definition unfoldEq (x:Inf) : x =
unfold x.
Proof.
intros.
destruct x as [x'].
simpl. exact eq_refl.
Defined.
(** We make a dummy goal to use
the "type of" function *)
Goal False.
(** [unfoldEq infinity] is of
type [infinity = S infinity] *)
match type of (unfoldEq infinity)
with
| ?T => let T' := eval simpl
in T in idtac T "," T'
end.
when we compute on [eqq
infinity] as shown above, we
get [eq_refl] which cannot be
of the type
because [S infinity] is not
definitionally equal to [infinity].
Eval compute in (unfoldEq
infinity).
(** This is a voilation of type
preservation*)
This message and any attachment are intended solely for the addressee and may contain confidential information. If you have received this message in error, please send it back to me, and immediately delete it. Please do not use, copy or disclose the information contained in this message or in any attachment. Any views or opinions expressed by the author of this email do not necessarily reflect the views of the University of Nottingham. This message has been checked for viruses but the contents of an attachment may still contain software viruses which could damage your computer system, you are advised to perform your own checks. Email communications with the University of Nottingham may be monitored as permitted by UK legislation. |
- [Coq-Club] Is Coq SN ?, Bas Spitters, 02/28/2016
- Re: [Coq-Club] Is Coq SN ?, Maxime Dénès, 02/28/2016
- Re: [Coq-Club] Is Coq SN ?, Abhishek Anand, 02/28/2016
- Re: [Coq-Club] Is Coq SN ?, roux cody, 02/28/2016
- Re: [Coq-Club] Is Coq SN ?, Luo, Zhaohui, 02/29/2016
- Re: [Coq-Club] Is Coq SN ?, Thorsten Altenkirch, 02/29/2016
- Re: [Coq-Club] Is Coq SN ?, Frédéric Blanqui, 02/29/2016
- Re: [Coq-Club] Is Coq SN ?, roux cody, 02/29/2016
- Re: [Coq-Club] Is Coq SN ?, Jonathan Leivent, 02/29/2016
- Re: [Coq-Club] Is Coq SN ?, Benoît Viguier, 02/29/2016
