- To: coq-club AT inria.fr
- Subject: Re: [Coq-Club] Equality in the assumptions
- Date: Tue, 1 Mar 2016 08:09:48 +0900
- Authentication-results: mail3-smtp-sop.national.inria.fr; spf=None smtp.pra=beviguier AT gmail.com; spf=Pass smtp.mailfrom=beviguier AT gmail.com; spf=None smtp.helo=postmaster AT mail-pa0-f45.google.com
- Ironport-phdr: 9a23:OpEHmhTPeukw0Yu3zKWCtdnqp9psv+yvbD5Q0YIujvd0So/mwa64ZxON2/xhgRfzUJnB7Loc0qyN4/+mBz1LucfJmUtBWaIPfidNsd8RkQ0kDZzNImzAB9muURYHGt9fXkRu5XCxPBsdMs//Y1rPvi/6tmZKSV3BPAZ4bt74BpTVx5zukbvipNuNMk4Q1XKUWvBbElaflU3prM4YgI9veO4a6yDihT92QdlQ3n5iPlmJnhzxtY+a9Z9n9DlM6bp6r5YTGfayQ6NtRrtBST8iLmod5cvxtBCFQxHcyGEbVzA8nxxPhRTy0hD1Q5b8qGOuvOdj2SaHPMDsZb8xUDWmqaxsTUm72288Kzcl/TSP2YRLh6VBrUf5qg==
I think you have an error in your example. Because trivial/reflexivity/auto... does the job. :/
Theorem my_theorem:forall (a b c: my_type), (my_ind a b) = (my_ind b c) -> 2 = 2.
Proof.
intros a b c H.
reflexivity.
Qed.
Hey all,
I am stuck in the middle of a proof.
In assumptions, I have an equality of two inductively defined propositions, and I need to make use of it. Here is a toy example to explain it:
Inductive my_type : Type :=
| one : my_type
| two : my_type
| other : nat -> my_type.
Inductive my_ind (a b:my_type) : my_type -> Prop :=
| cons_introl :forall x: my_type, b = one -> my_ind a b x
| cons_intror :forall x: my_type, a = one -> my_ind a b x.
Theorem my_theorem:forall (a b c: my_type), (my_ind a b) = (my_ind b c) -> 2=2.
Proof.
intros a b c H.
(*How sould I make use of H? inversion, injection, unfold, does not seem to work*)
(*I need to destruct two possible ways of constructing my_ind, and then prove the goal in each case*)
Abort.
Thank you very much
- Re: [Coq-Club] Equality in the assumptions, Benoît Viguier, 03/01/2016
- <Possible follow-up(s)>
- Re: [Coq-Club] Equality in the assumptions, Vadim Zaliva, 03/01/2016
- Re: [Coq-Club] Equality in the assumptions, Emilio Jesús Gallego Arias, 03/01/2016
