- From: Jacques-Henri Jourdan <jacques-henri.jourdan AT inria.fr>
- To: coq-club AT inria.fr
- Subject: Re: [Coq-Club] Program Definition vs. Program Fixpoint
- Date: Wed, 2 Mar 2016 15:01:56 +0100
The behavior is different in 8.4 (Fixpoint behaves like Definition in 8.4).
I think this deserves a bug report.
Le 02/03/2016 14:58, Ralf Jung a écrit :
> Hi all,
> I just noticed that there are some weird differences between Program
> Definition and Program Fixpoint, which force me to use Fixpoint even for
> some non-recursive definition unless I want to spell out some "_"
> explicitly:
> ---------- BEGIN --------------
> Require Import Program Omega.
> Definition foo (n : nat) {H : n > 5} := n.
> Program Fixpoint foo1 x := foo (x + 6).
> Next Obligation. omega. Qed.
> (* I would expect this to work. *)
> Fail Program Definition foo1 x := foo (x + 6).
> (* I can work around it, but it's ugly. *)
> Program Definition foo2 x := foo (x + 6) (H:=_).
> --------- END ------------
> Is this somehow a feature I do not understand, or is it an outright bug
> in "Program"?
> In any case, this can be problematic if what you are defining is not a
> function, i.e. does not have any arguments - in that case, you cannot
> use Fixpoint, so you have to be explicit about the "_".
> Kind regards,
> Ralf
signature.asc
Description: OpenPGP digital signature
- [Coq-Club] Program Definition vs. Program Fixpoint, Ralf Jung, 03/02/2016
- Re: [Coq-Club] Program Definition vs. Program Fixpoint, Jacques-Henri Jourdan, 03/02/2016
