- From: Peter Vanderbilt <acm AT petervanderbilt.com>
- To: "coq-club AT inria.fr" <coq-club AT inria.fr>
- Subject: [Coq-Club] How can eq be a Prop yet have a recurse?
- Date: Wed, 2 Mar 2016 11:06:19 -0800
- Authentication-results: mail3-smtp-sop.national.inria.fr; spf=None smtp.pra=acm AT petervanderbilt.com; spf=None smtp.mailfrom=acm AT petervanderbilt.com; spf=None smtp.helo=postmaster AT delivery.mailspamprotection.com
- Ironport-phdr: 9a23:sm/OQh0+/1C75pyvsmDT+DRfVm0co7zxezQtwd8ZsegQLfad9pjvdHbS+e9qxAeQG96LtLQb0aGP6v+ocFdDyKjCmUhKSIZLWR4BhJdetC0bK+nBN3fGKuX3ZTcxBsVIWQwt1Xi6NU9IBJS2PAWK8TWM5DIfUi/yKRBybrysXNWC0ILojavrosKbSj4LrQT+SIs6FA+xowTVu5teqqpZAYF19CH0pGBVcf9d32JiKAHbtR/94sCt4MwrqHwI6Lpyv/JHBO/xeL19RrhFBhwnNXo07Yvlr1OLGQCI/z4XVngcuhtOGQnMqh/gCMTfqCz/49JwxCSAdfP/S7w5Qz6j67sjHBbjjQ8fOiI06n/ejMB9lqhapA7nrBt6ld2HKLqJPeZzK/uONegRQnBMC55c
Consider the following definitions (where type eq1 is the same as the built-in equality, eq):
Inductive eq1 {A:Type} (a:A) : A -> Prop :=
refl1 : eq1 a a.
Inductive eq2 {A: Type} : A -> A -> Prop :=
refl2 a : eq2 a a.
Inductive eq3 {A: Type} : A -> A -> Type :=
refl3 a : eq3 a a.
I’m surprised that Coq generates recursion principles (eq1_rect and eq1_rec) for eq1 even though it’s a Prop.
As expected, there are recursion principles for eq3, but, not being a Prop, it can’t play with other Props (like it can’t be in a conjunction).
As expected, eq2 can play with other Props, but there’s only an induction principle, eq2_ind, so it can’t be used in non-Prop-returning expressions.
But eq1 can play with other Props and can be used in non-Prop-returning expressions. For instance:
Definition tr1 {A : Type} (B : A->Type) {x y : A} (p : eq1 x y) : B x -> B y
:= eq1_rect _ x (fun y => B x -> B y) (fun b => b) y p.
Isn’t this a problem for program extraction? Doesn’t extraction erase Prop-valued terms?
What is it about the definition of eq1 that signals Coq to generate a recursion principle?
Is it that eq1 has one constructor with no arguments and, so, it carries no information?
Is there a way to make a definition of the form of eq2 & eq3 be a Prop with recursion principles?
I’m using “Coq 8.5 (January 2016)”.
Pete
- [Coq-Club] How can eq be a Prop yet have a recurse?, Peter Vanderbilt, 03/02/2016
- Re: [Coq-Club] How can eq be a Prop yet have a recurse?, Robbert Krebbers, 03/03/2016
