- From: Pierre-Marie Pédrot <pierre-marie.pedrot AT inria.fr>
- To: coq-club AT inria.fr
- Subject: Re: [Coq-Club] Variables outside sections
- Date: Fri, 4 Mar 2016 17:19:32 +0100
On 04/03/2016 17:14, Igor Zhirkov wrote:
> The Coq reference manual says that using Variable keyword is equivalent
> to Local Parameter, but I failed to find any explanation of the Local
> Parameter itself.
The Parameter command is documented as being an alias for Axiom and,
Local Axiom is indeed described in the Axiom section:
https://coq.inria.fr/refman/Reference-Manual003.html#hevea_default34
PMP
signature.asc
Description: OpenPGP digital signature
- [Coq-Club] Variables outside sections, Igor Zhirkov, 03/04/2016
- Re: [Coq-Club] Variables outside sections, Pierre-Marie Pédrot, 03/04/2016
- Re: [Coq-Club] Variables outside sections, Jonathan Leivent, 03/04/2016
- Re: [Coq-Club] Variables outside sections, Igor Zhirkov, 03/04/2016
