coq-club - Re: [Coq-Club] Variables outside sections
  • To: coq-club AT inria.fr
  • Subject: Re: [Coq-Club] Variables outside sections
  • Date: Fri, 4 Mar 2016 11:26:16 -0500
  • Authentication-results: mail2-smtp-roc.national.inria.fr; spf=None smtp.pra=jonikelee AT gmail.com; spf=Pass smtp.mailfrom=jonikelee AT gmail.com; spf=None smtp.helo=postmaster AT mail-qg0-f48.google.com
  • Ironport-phdr: 9a23:4GyTQx1+EqZOZ7DtsmDT+DRfVm0co7zxezQtwd8ZsegTKfad9pjvdHbS+e9qxAeQG96LtLQb1aGG7+jJYi8p39WoiDg6aptCVhsI2409vjcLJ4q7M3D9N+PgdCcgHc5PBxdP9nC/NlVJSo6lPwWB6kO74TNaIBjjLw09fr2zQd6NyZvpnLDus7ToICx2xxOFKYtoKxu3qQiD/uI3uqBFbpgL9x3Sv3FTcP5Xz247bXianhL7+9vitMU7q3cYjdt6qJUFCfmyP/lgDO8QMDNzOGcsocbvqBPrTA2V53JaXH9FvABPBl3n6xfzQpf4tGPeu+tj1S+GdZn0SrY1Wjmm4qpDRxrhiSNBPDk8pjKEwvdshb5W9Ury7yd0xJTZNdzNOQ==
On 03/04/2016 11:14 AM, Igor Zhirkov wrote:
Hi all,
I was refreshing my memory on coercions lately and saw some strange behaviour
of Variables declared outside sections. MWE in Coq 8.5 :
Record mixin_of (T:Type) := Mixin { bogus: nat }.
Structure pack_type: Type := Pack { type: Type ; _ : mixin_of type }.
Coercion type: pack_type >-> Sortclass.
Variable cT: pack_type.
Check cT. (* prints cT: pack_type *)
Definition my_struct : mixin_of cT :=
match cT return mixin_of cT with
| Pack _ c => c
end.
Now that gives an error:
Toplevel input, characters 92-93:
Error:
In environment
T : Type
c : mixin_of T
The term "c" has type "mixin_of T" while it is expected to have type
"mixin_of cT".
Looks strange to me because Check cT found it.
It works however:
* if the code above is inside a section;
* if cT is added to the argument list manually;
The Coq reference manual says that using Variable keyword is equivalent to
Local Parameter, but I failed to find any explanation of the Local Parameter
itself. (link:
https://coq.inria.fr/refman/Reference-Manual003.html#hevea_default36
[https://coq.inria.fr/refman/Reference-Manual003.html#hevea_default36] ).
So, what is actually going on here and why an information about such a
variable is lost sometimes?
--Igor
Note that this works:
let x := cT in
match x return (mixin_of x) with
| Pack _ c => c
end.
although that might just add to the mystery.
-- Jonathan
