coq-club - Re: [Coq-Club] multiple typeclass instance question
  • To: coq-club AT inria.fr
  • Subject: Re: [Coq-Club] multiple typeclass instance question
  • Date: Wed, 9 Mar 2016 20:15:24 -0500
  • Authentication-results: mail2-smtp-roc.national.inria.fr; spf=None smtp.pra=jonikelee AT gmail.com; spf=Pass smtp.mailfrom=jonikelee AT gmail.com; spf=None smtp.helo=postmaster AT mail-qg0-f50.google.com
  • Ironport-phdr: 9a23:5UxVSR+rsZkbo/9uRHKM819IXTAuvvDOBiVQ1KB91ukcTK2v8tzYMVDF4r011RmSDdqdu60P0bqempujcFJDyK7JiGoFfp1IWk1NouQttCtkPvS4D1bmJuXhdS0wEZcKflZk+3amLRodQ56mNBXsq3G/pQQfBg/4fVIsYL+lRciC0I/th6ibwN76XUZhvHKFe7R8LRG7/036l/I9ps9cEJs30QbDuXBSeu5blitCLFOXmAvgtI/rpMYwuxJ54K16spYcGeWnJ+VrBYBfWT8hKiU+4NDhnRjFVwqGoHUGAUsMlR8dIQ/D5Q36V5G5lib7qOd7xGHOP8rwTLM5XTmvx6huQR7sziwAMmhqoynslsVsgfcD81qarBtlztuJOIw=
On 03/09/2016 08:05 PM, Matthieu Sozeau wrote:
You are basically asking for putting the pretyper in the tactic monad
here, so that refine could return multiple successes, right?
I wouldn't restrict it to "refine", if that's what you are implying. Actually, I'm not sure what you're implying.:-[ So, maybe this will clarify my request:
Class Foo : Type := { value : nat }.
Instance foo_a : Foo := {value := 42}.
Instance foo_b : Foo := {value := 7}.
Goal value = 7.
reflexivity.
Qed.
Goal value = 42.
Fail reflexivity.
Could this second goal be provable as well?
-- Jonathan
I think Arnaud had some ideas about this.
-- Matthieu
On Thu, Mar 10, 2016 at 1:08 AM Jonathan Leivent
<jonikelee AT gmail.com>
wrote:
I meant something more like this:
Class Foo : Type.
Instance foo_a : Foo.
Instance foo_b : Foo.
Goal True.
try (refine (let x := _ : Foo in _);
let y := eval unfold x in x in idtac y; fail).
The above prints only foo_b, because that is the most recent definition
(since their costs are the same). Using costs, one can make it so that
foo_a is printed, but not foo_b. But, is there a way to have something
print both foo_a and foo_b?
-- Jonathan
On 03/09/2016 06:49 PM, Vadim Zaliva wrote:
How about something like this:
Instance Zmult_op : monoid_binop Z | 1 := Zmult.
Instance Zplus_op : monoid_binop Z | 2 := Zplus.
(from
http://www.labri.fr/perso/casteran/CoqArt/TypeClassesTut/typeclassestut.pdf
Vadim
CMU ECE PhD candidate
Mobile: +1(510)220-1060
Skype: vzaliva
On Wed, Mar 9, 2016 at 1:38 PM, Jonathan Leivent
wrote:
Suppose one has multiple typeclass instances of the same exact class
(same
exact parameterization). Is there a way to get to more of them other
than
just the most recently declared one with the highest priority?
-- Jonathan
