- To: coq-club <coq-club AT inria.fr>
- Subject: Re: [Coq-Club] multiple typeclass instance question
- Date: Wed, 9 Mar 2016 21:06:44 -0500
- Authentication-results: mail3-smtp-sop.national.inria.fr; spf=None smtp.pra=jasongross9 AT gmail.com; spf=Pass smtp.mailfrom=jasongross9 AT gmail.com; spf=None smtp.helo=postmaster AT mail-ob0-f181.google.com
- Ironport-phdr: 9a23:vq3B1BJUvHoFGlclHdmcpTZWNBhigK39O0sv0rFitYgULvvxwZ3uMQTl6Ol3ixeRBMOAu60C27Wd7/iocFdDyKjCmUhKSIZLWR4BhJdetC0bK+nBN3fGKuX3ZTcxBsVIWQwt1Xi6NU9IBJS2PAWK8TWM5DIfUi/yKRBybrysXNWC0ILniKvuo9X6WEZhunmUWftKNhK4rAHc5IE9oLBJDeIP8CbPuWZCYO9MxGlldhq5lhf44dqsrtY4q3wD86Fpy8kVWqLjOq88ULYQWD8hKiU+4NDhnRjFVwqGoHUGBDY4iB1NVirM9xb8FrjrtTDh/r5/0TKdO8LsSqsvCByt6q5qTFnjjyJRZG1xy33elsEl1PETmxmmvREqm4M=
> But, is there a way to have something print both foo_a and foo_b?
Axiom A : Type.
Existing Class A.
Axioms a a' : A.
Existing Instances a a'.
Class MultiA {x : A} := dummy : True.
Hint Extern 0 (@MultiA ?x) => idtac x; fail : typeclass_instances.
Goal True.
try pose (_ : MultiA).
(* a'
a
a'
a
a'
a
a'
a *)
Not sure why there's so much duplication, but can you make this work?
On Wed, Mar 9, 2016 at 8:28 PM, Jonathan Leivent <jonikelee AT gmail.com> wrote:
On 03/09/2016 08:15 PM, Jonathan Leivent wrote:
On 03/09/2016 08:05 PM, Matthieu Sozeau wrote:
You are basically asking for putting the pretyper in the tactic monad
here, so that refine could return multiple successes, right?
I wouldn't restrict it to "refine", if that's what you are implying. Actually, I'm not sure what you're implying.:-[ So, maybe this will clarify my request:
Class Foo : Type := { value : nat }.
Instance foo_a : Foo := {value := 42}.
Instance foo_b : Foo := {value := 7}.
Goal value = 7.
reflexivity.
Qed.
Goal value = 42.
Fail reflexivity.
Could this second goal be provable as well?
No - I can see that won't ever work. The implicit Foo argument of value is already filled in as foo_b. OK - then I guess I'm really talking about this goal:
Goal exists f, @value f = 42.
in which case, making refine see multiple successes would work, via "refine (ex_intro _ _ _); reflexivity.".
Although, it would be interesting if the "Goal value = 42" were actually interpreted roughly as "Goal exists f, @value f = 42." In other words, delaying the implicit arg somehow.
-- Jonathan
- [Coq-Club] multiple typeclass instance question, Jonathan Leivent, 03/09/2016
- Re: [Coq-Club] multiple typeclass instance question, Vadim Zaliva, 03/10/2016
- Re: [Coq-Club] multiple typeclass instance question, Jonathan Leivent, 03/10/2016
- Re: [Coq-Club] multiple typeclass instance question, Matthieu Sozeau, 03/10/2016
- Re: [Coq-Club] multiple typeclass instance question, Jason Gross, 03/10/2016
- Re: [Coq-Club] multiple typeclass instance question, Arnaud Spiwack, 03/11/2016
- Re: [Coq-Club] multiple typeclass instance question, Jonathan Leivent, 03/11/2016
- Re: [Coq-Club] multiple typeclass instance question, Pierre-Marie Pédrot, 03/12/2016
- Re: [Coq-Club] multiple typeclass instance question, Arnaud Spiwack, 03/13/2016
- Re: [Coq-Club] multiple typeclass instance question, Jonathan Leivent, 03/13/2016
