coq-club - [Coq-Club] Problem with types in the Compile Time Parsing pearl.
  • To: coq-club AT inria.fr
  • Subject: [Coq-Club] Problem with types in the Compile Time Parsing pearl.
  • Date: Sun, 13 Mar 2016 19:56:09 +0100
  • Authentication-results: mail2-smtp-roc.national.inria.fr; spf=None smtp.pra=Lars.Rasmusson AT sics.se; spf=Pass smtp.mailfrom=lra AT sics.se; spf=None smtp.helo=postmaster AT mail-lb0-f177.google.com
  • Ironport-phdr: 9a23:ODnERBTPc63ZFDYqtKDjwUGfU9psv+yvbD5Q0YIujvd0So/mwa64YBaN2/xhgRfzUJnB7Loc0qyN4/+mCDBLuMzY+Fk5M7VyFDY9wf0MmAIhBMPXQWbaF9XNKxIAIcJZSVV+9Gu6O0UGUOz3ZlnVv2HgpWVKQka3CwN5K6zPF5LIiIzvjqbpq8KVMlkD3WDkKZpJbzyI7izp/vEMhoVjLqtjgjDomVBvP9ps+GVzOFiIlAz97MrjtLRq8iBXpu5zv5UYCfayLOwESulTCy1jOGQo7uXqswPCRE2B/CgySGITxz5BGRON1hjhW4rqqSz8/r5Z0TOBe/f/VrUpQi+l6Y9wSRTzzjwKYW1quFrLg9B92foI6CmqoAZyltbZ
Hi,
I'm trying to implement the postfix parser in sec. 3.1 of Ralf Hinze's Functional Pearl Compile Time Parsing [1] (for Haskell) with the definitions of Monad and the Continuation Passing Style Monad given below.
To do that I need to be able to type  for instance this term.
   (return_ tt _ leaf)
but Coq gives the error below.  Is there some way to type this program in Coq?
(Probably I have made an error somewhere, but I'm not able to spot it.)
Thankful for any help!
/Lars
[1] http://www.cs.ox.ac.uk/people/ralf.hinze/publications/Quote.pdf
Class Monad (m: Type -> Type): Type :=
    return_ {A}:     A -> m A;
    bind    {A B}:   m A -> (A -> m B) -> m B;
    right_unit {A}:  forall (a: m A), bind a return_ = a;
    left_unit  {A}:  forall (a: A) B (f: A -> m B),
                       bind (return_ a) f = f a;
    associativity {A B C}:
                     forall a (f: A -> m B) (g: B -> m C),
                       bind a (fun x => bind (f x) g) = bind (bind a f) g
Notation "a >>= f" := (bind a f) (at level 50, left associativity).
Definition lift {m} {M:Monad m} {A B: Type} (f: A->B) (a: A): m B :=
  return_ (f a).
Definition CPS (S:Type) := forall A, (S->A) -> A.
Instance CPSMonad : Monad CPS  :=
    return_ S s A f := f s ;
    bind    A B m k C c := m _ (fun a => k a _ c)
auto. auto. auto. Defined.
Inductive Tree := Leaf | Fork (_ _:Tree).
Definition leaf_ ST (st:ST) := (st, Leaf).
Definition leaf {ST:Type}   := lift (leaf_ ST).
Definition
(* this works *)
Check (return_ tt) >>= leaf.
(* this doesn't work *)
Check return_ tt _ leaf.
Toplevel input, characters 19-23:
Error:
The term "leaf" has type "unit -> CPS (unit * Tree)"
while it is expected to have type "unit -> ?T"
(unable to find a well-typed instantiation for "?T": cannot ensure that
"Type@{max(Top.27, Top.29+1)}" is a subtype of "Type@{Top.29}").
(* More like in the paper, just for fun
Module example.
  Definition quote := return_ tt.
  Definition fork_ ST (st:(ST * Tree) * Tree) :=
    match st with ((st',l),r) => (st', Fork l r) end.
  Definition fork {ST}               := lift (fork_ ST).
  Definition endquote (st:unit*Tree) := match st with (_,t) => t end.
  (* this constructs the Tree (Fork Leaf Leaf) *)
  Compute (quote >>= leaf >>= leaf >>= fork >>= (lift endquote)) _ (fun x=>x).
  Arguments quote {_} _.
  (* this should do the same but fails with the same error as above*)
  Check quote leaf leaf fork endquote.
End example.
