- From: Pierre-Marie Pédrot <pierre-marie.pedrot AT inria.fr>
- To: coq-club AT inria.fr
- Subject: Re: [Coq-Club] Problem with types in the Compile Time Parsing pearl.
- Date: Sun, 13 Mar 2016 20:02:50 +0100
On 13/03/2016 19:56, Lars Rasmusson wrote:
> (Probably I have made an error somewhere, but I'm not able to spot it.)
Your monad is a CPS, which typically requires impredicativity of the
target sort to be run into the same sort. I think this is why your
example fails. If this is the case, there is not much to do to be able
to port this code to Coq, except maybe using the -impredicative-set flag.
PMP
signature.asc
Description: OpenPGP digital signature
- [Coq-Club] Problem with types in the Compile Time Parsing pearl., Lars Rasmusson, 03/13/2016
- Re: [Coq-Club] Problem with types in the Compile Time Parsing pearl., Pierre-Marie Pédrot, 03/13/2016
- Re: [Coq-Club] Problem with types in the Compile Time Parsing pearl., Roger Witte, 03/13/2016
- Re: [Coq-Club] Problem with types in the Compile Time Parsing pearl., Lars Rasmusson, 03/15/2016
