- To: coq-club AT inria.fr
- Subject: Re: [Coq-Club] are type indexes ever necessary?
- Date: Tue, 22 Mar 2016 22:47:02 -0400
- Authentication-results: mail2-smtp-roc.national.inria.fr; spf=None smtp.pra=jonikelee AT gmail.com; spf=Pass smtp.mailfrom=jonikelee AT gmail.com; spf=None smtp.helo=postmaster AT mail-qk0-f178.google.com
- Ironport-phdr: 9a23:cjjqdhNkVcTpLmqa74Ql6mtUPXoX/o7sNwtQ0KIMzox0KP/yrarrMEGX3/hxlliBBdydsKIUzbOL+P28EUU7or+/81k6OKRWUBEEjchE1ycBO+WiTXPBEfjxciYhF95DXlI2t1uyMExSBdqsLwaK+i760zceF13FOBZvIaytQ8iJ35Txjr35psGbSj4LrQT+SIs6FA+xowTVu5teqqpZAYF19CH0pGBVcf9d32JiKAHbtR/94sCt4MwrqHwI6Lpyv/JHBK79ZuEzSaFSJDUgKWE8osPx5jfZSg7axHwaW3kWmxwAJwXE8hz8Qt+lsCz8t+lw3CSXFcLzRLEwHz+l6vE4G1fTlC4bOmthoynsgctqgfcDrQ==
On 03/22/2016 02:37 PM, Cedric Auger wrote:
2016-03-21 20:03 GMT+01:00 Jonathan Leivent
<jonikelee AT gmail.com
<mailto:jonikelee AT gmail.com>>:
Is it true in Coq that any index on an inductive type could *always* be
replaced by a type parameter with an extra equality-typed field added to
each constructor tying the type parameter to that constructor's value
for it?
I think it is always the case. One cannot prove it directly in Coq as we
would
have to use "meta"functions taking a type as argument, and inspect its
construction to build an other one which would be isomorphic.
Thanks. I did not expect it to be provable in Coq. I was just wondering if, by avoiding type indexes, I'd eventually find a good reason to have kept them.
Now I tend to avoid that kind of annoyance with an other approach:
Inductive finS(X:Set) : Set :=
| Fin1
| FinS : X -> finS X.
Fixpoint fin(m:nat) : Set :=
match m with
| O => emptySet
| S n => finS (fin m)
end.
I find this kind of type quite convenient to use. "inversion f." becomes
"destruct n; destruct f." with no weirdness to deal with.
Induction is done on the parameter rather than the type, and all basic
operation
have their counterparts in a not too artificial way.
I find it nice to have the ability to "reduce" the type to only those which
are
possible in a given context.
I am conscious on the fact that such a transcription of type is not always
trivially existent, but in many cases, there is a strong relation between the
constructor of the type and the constructors of the index, leading to a
natural
way to make it.
Cases which do not apply still, are those where the index is not a constructed
type (and I don’t pretend this to be the only case).
Example: Inductive is_identity {A:Type} : (A->A)->Prop := Id : is_identity
(fun
x => x).
This construction is interesting, but not useful in most of my cases. The issue is that I want the type parameters and indexes to vanish via Extraction along with all trace of their trails through the code, and incorporating one as a match discriminee will likely prevent that.
-- Jonathan
- [Coq-Club] are type indexes ever necessary?, Jonathan Leivent, 03/21/2016
- Re: [Coq-Club] are type indexes ever necessary?, Cedric Auger, 03/22/2016
- Re: [Coq-Club] are type indexes ever necessary?, Jonathan Leivent, 03/23/2016
- Re: [Coq-Club] are type indexes ever necessary?, Matthieu Sozeau, 03/25/2016
