coq-club - Re:[Coq-Club]
Re:[Coq-Club]
  • From: Clément Pit--Claudel <clement.pit AT gmail.com>
  • To: coq-club AT inria.fr
  • Subject: Re:[Coq-Club]
  • Date: Wed, 30 Mar 2016 19:55:07 +0200
  • Authentication-results: mail2-smtp-roc.national.inria.fr; spf=None smtp.pra=clement.pit AT gmail.com; spf=SoftFail smtp.mailfrom=clement.pit AT gmail.com; spf=None smtp.helo=postmaster AT mout.kundenserver.de
  • Ironport-phdr: 9a23:xy6yqRONDyJcasgW46gl6mtUPXoX/o7sNwtQ0KIMzox0KPj8rarrMEGX3/hxlliBBdydsKIUzbCG+Pm5ByQp2tWojjMrSNR0TRgLiMEbzUQLIfWuLgnFFsPsdDEwB89YVVVorDmROElRH9viNRWJ+iXhpQAbFhi3DwdpPOO9QteU1JTnkbrisMSKPU1hv3mUX/BbFF2OtwLft80b08NJC50a7V/3mEZOYPlc3mhyJFiezF7W78a0+4N/oWwL46pyv50IbaKvdKMhCLdcET4OMmYv5cStuwOQYxGI4y43VuQTnxxUNDDE8FS/dZP4ryf3sqIp0y2XOMDwUfYsWCiK4KJiSRuugyACYW1quFrLg9B92foI6CmqoAZyltbZ
On 03/30/2016 04:48 PM, Thorsten Altenkirch wrote:
> I don¹t know what Maxime said, but it rather seems that functional
> extensionality can reveal problems with other principles. However, it is
> very wrong then to blame functional extensionality.
Fortunately, that's not what I was doing :) I was talking about propositional
extensionality (see the mail that you quoted).
> On 30/03/2016 13:40, "Clément Pit--Claudel"
> wrote:
>> It's a pretty heavy axiom, but it should be fine. Would rephrasing your
>> original lemma to use an equivalence instead of equality work, though?
>> If not, see https://coq.inria.fr/cocorico/CoqAndAxioms and
>> https://coq.inria.fr/faq#htoc36 for background on using axioms with Coq.
>> Best,
>> Clément.
>> On 03/30/2016 02:27 PM, Benoît Viguier wrote:
>>> Hi,
>>> thanks for your quick answers. Is there any risk I should know while
>>> using this Axiom ? It seemed it was inconsistent with Coq termination in
>>> late 2013 cf Maxime Dénès talk.
>>> Regards.
>>> Benoît
>>> 2016-03-30 13:36 GMT+02:00 Clément Pit--Claudel
>>> <mailto:clement.pit AT gmail.com>>:
>>> On 03/30/2016 01:12 PM, Benoît Viguier wrote:
>>> > Can someone explain me why I am not allowed to complete this
>>> proof ? Using the functionnal extensionality, it should be right. No ?
>>> No. You need Prop Extensionality for that rewrite to be valid.
>>> Axiom prop_ext : forall (P Q : Prop),
>>> (P <-> Q) -> P = Q.
>>> apply prop_ext.
>>> rewrite Nat.leb_le.
>>> reflexivity.
>>> Clément.
> This message and any attachment are intended solely for the addressee
> and may contain confidential information. If you have received this
> message in error, please send it back to me, and immediately delete it.
> Please do not use, copy or disclose the information contained in this
> message or in any attachment. Any views or opinions expressed by the
> author of this email do not necessarily reflect the views of the
> University of Nottingham.
> This message has been checked for viruses but the contents of an
> attachment may still contain software viruses which could damage your
> computer system, you are advised to perform your own checks. Email
> communications with the University of Nottingham may be monitored as
> permitted by UK legislation.
Attachment: signature.asc
Description: OpenPGP digital signature
