coq-club - Re: [Coq-Club] Elim of existential hypothesis => Error: Cannot find the elimination combinator ex_rect
  • To: coq-club AT inria.fr
  • Subject: Re: [Coq-Club] Elim of existential hypothesis => Error: Cannot find the elimination combinator ex_rect
  • Date: Mon, 30 May 2016 11:57:02 -0400
  • Authentication-results: mail2-smtp-roc.national.inria.fr; spf=None smtp.pra=adamc AT csail.mit.edu; spf=Pass smtp.mailfrom=adamc AT csail.mit.edu; spf=None smtp.helo=postmaster AT outgoing-tmp.csail.mit.edu
  • Ironport-phdr: 9a23:G64mEB/bgHrNO/9uRHKM819IXTAuvvDOBiVQ1KB90OwcTK2v8tzYMVDF4r011RmSDdSdtqkP2rCempujcFJDyK7JiGoFfp1IWk1NouQttCtkPvS4D1bmJuXhdS0wEZcKflZk+3amLRodQ56mNBXsq3G/pQQfBg/4fVIsYL+lS8iP1I/mjaibwN76XUZhvHKFe7R8LRG7/036l/I9ps9cEJs30QbDuXBSeu5blitCLFOXmAvgtI/rpMYwu3cYh/V0/MlZFK7+Yq4QTLpCDT1gPXpmytfssEzqQQKKrlAcVmQOmx5BS1zM4Bj/Vb/6qSL7sqx42TXcMMHrG+NnEQ++5rtmHUe7wBwMMCQ0pTna
[exists] produces [Prop]s, while your predicate [p] returns [Type].  It is a fundamental property of Coq that details of proofs of [Prop]s can never influence non-[Prop]-y things.  Your [p] is an example of a non-[Prop]-y thing here.
In deriving a proof-relevant recursion principle like this one, you should only rely on lemmas that use proof-relevant types.  For instance, you can use [sig] instead of [exists].
On 05/30/2016 11:44 AM, Soegtrop, Michael wrote:
I am way stuck trying to use an existential hypothesis with elim:
1 subgoal
t : Type
p : list t -> Type
H0 : p [ ]
HS : forall (x : t) (l : list t), p (l ++ [x])
x : t
l : list t
HM : exists (x2 : t) (l2 : list t), l ++ [x] = [x2] ++ l2
______________________________________(1/1)
p ([x] ++ l)
