Re: [Coq-Club] Elim of existential hypothesis => Error: Cannot find the elimination combinator ex_rect
- From: Arnaud Spiwack <aspiwack AT lix.polytechnique.fr>
- To: Coq Club <coq-club AT inria.fr>
- Subject: Re: [Coq-Club] Elim of existential hypothesis => Error: Cannot find the elimination combinator ex_rect
- Date: Tue, 31 May 2016 13:34:10 +0200
- Authentication-results: mail3-smtp-sop.national.inria.fr; spf=None smtp.pra=arnaud.spiwack AT gmail.com; spf=Pass smtp.mailfrom=arnaud.spiwack AT gmail.com; spf=None smtp.helo=postmaster AT mail-vk0-f48.google.com
- Ironport-phdr: 9a23:ojYKUxQVnXPf1cOLRUYVfQtRmtpsv+yvbD5Q0YIujvd0So/mwa64bBSN2/xhgRfzUJnB7Loc0qyN4/GmBDFLusfJmUtBWaIPfidNsd8RkQ0kDZzNImzAB9muURYHGt9fXkRu5XCxPBsdMs//Y1rPvi/6tmZKSV3BPAZ4bt74BpTVx5zukbviqtuOPk4T1XKUWvBbElaflU3prM4YgI9veO4a6yDihT92QdlQ3n5iPlmJnhzxtY+a9Z9n9DlM6bp6r5YTGY2zRakzTKRZATI6KCh1oZSz7ViQBTeIs1AbSy09lgdCS1zO6wi/VZPsuAP7sPB80W+UJ5ulY6ozXGGL9aFiVROgsz8GKDcy8ymDg9dojb1SqxGJox1vhZbTZJCJOfF+eKLEYN5cS3AXDZUZbDBIHo7pN9hHNOEGJ+sN6tCl/1Y=
As a theoretical point: there are two kinds of things from Prop
which cannot be eliminated to produce something in Type
- Disjunctions
P\/Q
- Existentials
exists x:A, P
Their elimination is disallowed because it would expose “information” from the proof of a proposition to a computation (it would prevent things like extraction, for instance). But the case of existential is a bit different because allowing elimination would be inconsistent (in that False
would be provable).
This is a rather technical result. It is an instance of https://coq.inria.fr/distrib/current/stdlib/Coq.Logic.Hurkens.html#NoRetractFromTypeToProp where you would use exists x:A, True
for down A
then up
would be the elimination of the existential.
On 31 May 2016 at 11:18, Dominique Larchey-Wendling <dominique.larchey-wendling AT loria.fr> wrote:
Dear Michael,
> I am way stuck trying to use an existential hypothesis with elim:
> 1 subgoal
> t : Type
> p : list t -> Type
> H0 : p [ ]
> HS : forall (x : t) (l : list t), p (l ++ [x])
> x : t
> l : list t
> HM : exists (x2 : t) (l2 : list t), l ++ [x] = [x2] ++ l2
> ______________________________________(1/1)
> p ([x] ++ l)
> now I want to elim HM to get the equation to rewrite the goal, so that I
> can use HS to solve it. But when I try “elim HM” I get the error “Error:
> Cannot find the elimination combinator ex_rect, the elimination of the
> inductive definition ex on sort Type is probably not allowed.”.
As Adam said, it is a useful feature of Coq to NOT allow the destruction
of an inductively defined term of type Prop to build a term of type
Type (or Set).
This way, you can add axioms in Prop without having to realize those
axioms during the extraction process. The idea is that propositions
cannot contribute to computations but only to (show) their correctness.
There are some exceptions though: when the inductive Prop is defined
by either 0 (eg False) or 1 (eg conj) constructor/rule, you can destruct
the constructor because it contains no computational content (ie choice)
in those two cases (0 or 1).
Regarding the solution to your problem, notice that you can prove
HM (or the reversed version I suggest here) directly for any l x.
Require Import List.
Section test.
Variables (t : Type).
Implicit Type (l : list t).
Fact invert_Prop l : forall x, exists x2 l2, l2 ++ x2::nil = (x::nil)
++ l.
Proof.
induction l as [ | y l IHl ]; intros x.
exists x, nil; auto.
destruct (IHl y) as (x2 & l2 & H).
exists x2, (x::l2); auto.
simpl; f_equal; auto.
Qed.
Fact invert_Type l : forall x, { x2 : _ & { l2 | l2 ++ x2::nil =
(x::nil) ++ l } }.
Proof.
Qed.
Variables (p : list t -> Type) (H0 : p nil)
(HS : forall (x : t) (l : list t), p (l ++ x :: nil))
(x : t) (l : list t).
Goal p ((x :: nil) ++ l).
Proof.
destruct (invert_Type l x) as (x2 & l2 & H2).
rewrite <- H2; auto.
Qed.
End test.
You cannot destruct invert_Prop while proving the goal
but you can destruct invert_Type ...
Both invert_Prop and invert_Type have the very
same proof script (which does not mean that they
share the same proof term). Of course this corresponds
to the idea of replacing exists with either sig or sigT.
({ ... & ...} is a notation for sigT
and { ... | ... } a notation for sig.
Best regards,
Dominique
- [Coq-Club] Elim of existential hypothesis => Error: Cannot find the elimination combinator ex_rect, Soegtrop, Michael, 05/30/2016
- Re: [Coq-Club] Elim of existential hypothesis => Error: Cannot find the elimination combinator ex_rect, Adam Chlipala, 05/30/2016
- Re: [Coq-Club] Elim of existential hypothesis => Error: Cannot find the elimination combinator ex_rect, Jonathan Leivent, 05/30/2016
- RE: [Coq-Club] Elim of existential hypothesis => Error: Cannot find the elimination combinator ex_rect, Soegtrop, Michael, 05/30/2016
- Re: [Coq-Club] Elim of existential hypothesis => Error: Cannot find the elimination combinator ex_rect, Tej Chajed, 05/30/2016
- RE: [Coq-Club] Elim of existential hypothesis => Error: Cannot find the elimination combinator ex_rect, Soegtrop, Michael, 05/31/2016
- Re: [Coq-Club] Elim of existential hypothesis => Error: Cannot find the elimination combinator ex_rect, Dominique Larchey-Wendling, 05/31/2016
- Re: [Coq-Club] Elim of existential hypothesis => Error: Cannot find the elimination combinator ex_rect, Arnaud Spiwack, 05/31/2016
