coq-club - Re: [Coq-Club] Mechanically generated functional induction principle?
  • From: Dominique Larchey-Wendling <dominique.larchey-wendling AT loria.fr>
  • To: coq-club AT inria.fr
  • Subject: Re: [Coq-Club] Mechanically generated functional induction principle?
  • Date: Mon, 20 Jun 2016 16:08:19 +0200
  • Organization: LORIA
Btw, a usefull application of the dependent induction principle
is the decidability of equality over ptrm for instance:
Definition list_eq_dec X (ll mm : list X) : (forall x y, Occ x ll -> Occ
y mm -> { x = y } + { x <> y }) -> { ll = mm } + { ll <> mm }.
Proof.
revert mm; induction ll as [ | x ll IH ]; intros [ | y mm ] IHll.
left; auto.
right; discriminate.
destruct (IHll x y) as [ | C ].
left; auto.
left; auto.
2: right; contradict C; injection C; auto.
subst y.
destruct IH with (mm := mm) as [ | C ].
intros; apply IHll; right; auto.
left; subst; auto.
Qed.
Definition ptrm_eq_dec (s t : ptrm) : { s = t } + { s <> t }.
Proof.
revert t; induction s as [ | a ll IHa IHll ] using ptrm_rect.
intros [ | ]; [ left | right ]; auto; discriminate.
intros [ | b mm ].
destruct (IHa b) as [ | C ].
subst b.
destruct (list_eq_dec ll mm) as [ | C ].
intros; apply IHll; auto.
left; subst; auto.
Qed.
On 06/20/2016 03:29 PM, Dominique Larchey-Wendling wrote:
> Dear Randy,
> I am not sure this is an answer to your problem in its full generality
> but regarding the difficulty of working in Coq with nested inductive
> type like ptrm, I suggest you write a powerful dependent induction
> principle by hand corresponding to your nested type. For instance,
> this is what I would do in the case of ptrm:
> Best regards,
> Dominique
> Require Import List.
> Set Implicit Arguments.
> (* The type of occurences in a list *)
> Fixpoint Occ X (x : X) ll : Set :=
> match ll with
> | nil => False
> | y::ll => ((x = y) + Occ x ll)%type
> end.
> (* The nested elimination Scheme generated by Coq is too weak *)
> Unset Elimination Schemes.
> Inductive ptrm : Set :=
> | ptRel : ptrm
> | ptApp : ptrm -> list ptrm -> ptrm.
> Set Elimination Schemes.
> (* I suggest writing a much more powerful one like this dependent one *)
> Section ptrm_rect.
> Variable P : ptrm -> Type.
> Hypothesis HP_Rel : P (ptRel).
> Hypothesis HP_App : forall a ll, P a -> (forall x, Occ x ll -> P x) ->
> P (ptApp a ll).
> Fixpoint ptrm_rect t : P t.
> Proof.
> refine(
> match t return P t with
> | ptRel => HP_Rel
> | ptApp a ll => HP_App _ (ptrm_rect a) _
> end).
> induction ll as [ | y ll IH ]; intros x.
> intros [].
> intros [ H | H ].
> subst x.
> apply ptrm_rect.
> apply IH, H.
> Defined.
> (* with the fixpoint equations that are crucial if you want to
> program (and not just prove) with the recursion principle *)
> Hypothesis HP_App_ext : forall a ll pa f1 f2,
> (forall x Hx, f1 x Hx = f2 x Hx)
> -> @HP_App a ll pa f1 = HP_App ll pa f2.
> Fact ptrm_rect_Rel_fix : ptrm_rect ptRel = HP_Rel.
> Proof. reflexivity. Qed.
> Fact ptrm_rect_App_fix a ll :
> ptrm_rect (ptApp a ll)
> = HP_App ll (ptrm_rect a) (fun t _ => ptrm_rect t).
> Proof.
> simpl.
> apply HP_App_ext.
> clear a; intros a Ha.
> induction ll; destruct Ha; simpl; subst; auto.
> Qed.
> End ptrm_rect.
> Section ptrm_recursion.
> (* the particular case when the output type does not depend on the ptrm
> is usually easier to work with, if the full dependent principle is not
> required
> the extensionality assumption fades away
> Variables (Y : Type)
> (y : Y)
> (f : ptrm -> list ptrm -> Y -> list Y -> Y).
> Definition ptrm_recursion : ptrm -> Y.
> Proof.
> apply ptrm_rect.
> exact y.
> intros x ll Hx Hll.
> apply (f x ll Hx).
> clear x Hx f.
> induction ll as [ | x ll IH ].
> exact nil.
> apply cons.
> apply Hll with x; left; auto.
> apply IH.
> intros a Ha; apply Hll with a; right; assumption.
> Defined.
> (* these are the fixpoint equations you want *)
> Fact ptrm_recursion_Rel_fix : ptrm_recursion ptRel = y.
> Proof.
> simpl; auto.
> Qed.
> Fact ptrm_recursion_App_fix a ll :
> ptrm_recursion (ptApp a ll)
> = f a ll (ptrm_recursion a) (map ptrm_recursion ll).
> Proof.
> unfold ptrm_recursion at 1.
> rewrite ptrm_rect_App_fix.
> f_equal.
> induction ll; simpl; f_equal; auto.
> clear a ll.
> intros a ll pa f1 f2 H12.
> f_equal.
> Qed.
> End ptrm_recursion.
> (* now you can use the ptrm_recursion principle to write your size
> function *)
> Definition ptrmSize (t:ptrm) : nat.
> Proof.
> induction t as [ | a ll IHa IHll ] using ptrm_recursion.
> exact 1.
> exact (S (IHa + fold_left (fun x y => x + y) IHll 0)).
> Defined.
> (* and prove the two fixpoint equations that you need for this size
> function *)
> Fact ptrmSize_Rel_fix : ptrmSize ptRel = 1.
> Proof. auto. Qed.
> Fact fold_left_map_plus X (f : X -> nat) ll n : fold_left (fun x y => x
> + y) (map f ll) n = fold_left (fun x y => x + f y) ll n.
> Proof.
> revert n; induction ll; intros n; simpl; f_equal; auto.
> Qed.
> Fact ptrmSize_App_Fix a ll : ptrmSize (ptApp a ll) = S (ptrmSize a +
> fold_left (fun x y => x + ptrmSize y) ll 0).
> Proof.
> rewrite <- fold_left_map_plus.
> unfold ptrmSize at 1.
> apply ptrm_recursion_App_fix.
> Qed.
> On 06/20/2016 12:46 PM, Randy Pollack wrote:
>> Consider the well known contrasting approaches to definition:
>> | ptRel : ptrm
>> Inductive Trm : Set :=
>> | TRel : Trm
>> | TApp : Trm -> Trms -> Trm
>> with Trms : Set :=
>> | tnil : Trms
>> | tcons : Trm -> Trms -> Trms.
>> It is possible to directly define a size function for both definitions
>> of terms, e.g.
>> Function ptrmSize (t:ptrm) : nat :=
>> match t with
>> | ptRel => 1
>> | ptApp fn args =>
>> S (ptrmSize fn +
>> (fold_left (fun x y => x + ptrmSize y) args 0))
>> end.
>> Function TrmSize (t:Trm) : nat :=
>> match t with
>> | TRel => 1
>> | TApp fn args => S (TrmSize fn + TrmsSize args)
>> end
>> with TrmsSize (ts:Trms) : nat :=
>> match ts with
>> | tnil => 0
>> | tcons u us => (TrmSize u + TrmsSize us)
>> end.
>> BUT, the definition of ptrmSize in Coq (8.5pl1) is not able to
>> mechanically generate a functional induction principle, while the
>> definition of TrmSize is able to generate a functional induction
>> principle.
>> Is there a definition of size for ptrm that can mechanically generate
>> a functional induction principle? (I insist on "mechanically
>> generate" because my real application is much bigger than this
>> example, and I'm interested in functions other than "size".)
>> I know of one way to do it: recurse over something different than the
>> term structure. E.g. use a "fuel" parameter:
>> Function ptrmSize' (n:nat) (t:ptrm) {struct n} : option nat :=
>> match n with
>> | 0 => None
>> | S n => match t with
>> | ptRel => Some 1
>> | ptApp fn args =>
>> match ptrmSize' n fn, ptrmsSize n args with
>> | Some x, Some y => Some (S (x + y))
>> | _, _ => None
>> end
>> end
>> end
>> with ptrmsSize (n:nat) (ts:list ptrm) {struct n} : option nat :=
>> match n with
>> | 0 => None
>> | S n => match ts with
>> | nil => Some 0
>> | cons u us =>
>> match ptrmSize' n u, ptrmsSize n us with
>> | Some x, Some y => Some (x + y)
>> | _, _ => None
>> end
>> end
>> end.
>> Does anyone know a cleaner way?
>> Thanks,
>> Randy
