coq-club - [Coq-Club] Mechanically generated functional induction principle?
  • To: Coq-Club Club <coq-club AT inria.fr>
  • Subject: [Coq-Club] Mechanically generated functional induction principle?
  • Date: Mon, 20 Jun 2016 11:46:00 +0100
  • Authentication-results: mail3-smtp-sop.national.inria.fr; spf=None smtp.pra=rpollack0 AT gmail.com; spf=Pass smtp.mailfrom=rpollack0 AT gmail.com; spf=None smtp.helo=postmaster AT mail-lf0-f68.google.com
  • Ironport-phdr: 9a23:oganvhOzkMJ0DKmT/aAl6mtUPXoX/o7sNwtQ0KIMzox0KPv/rarrMEGX3/hxlliBBdydsKIVzbuL+Pm8EUU7or+/81k6OKRWUBEEjchE1ycBO+WiTXPBEfjxciYhF95DXlI2t1uyMExSBdqsLwaK+i760zceF13FOBZvIaytQ8iJ35Xxhr35osGbSj4LrQT+SIs6FA+xowTVu5teqqpZAYF19CH0pGBVcf9d32JiKAHbtR/94sCt4MwrqHwI6LoJvvRNWqTifqk+UacQTHF/azh0t4XXskzoShLKzX8BWC09lgdCS1zO6wi/VZPsuAP7sPB80W+UJ5ulY6ozXGGY5qFnWVfQjyMDPjU6uDXNkst0iKtQo0qJqBl2woqSa4aQYqktNpjBdM8XEDISFv1aUDZMV8blN9MC
Consider the well known contrasting approaches to definition:
Inductive ptrm : Set :=
| ptRel : ptrm
| ptApp : ptrm -> list ptrm -> ptrm.
Inductive Trm : Set :=
| TRel : Trm
| TApp : Trm -> Trms -> Trm
with Trms : Set :=
| tnil : Trms
| tcons : Trm -> Trms -> Trms.
It is possible to directly define a size function for both definitions
of terms, e.g.
Function ptrmSize (t:ptrm) : nat :=
match t with
| ptRel => 1
| ptApp fn args =>
S (ptrmSize fn +
(fold_left (fun x y => x + ptrmSize y) args 0))
end.
Function TrmSize (t:Trm) : nat :=
match t with
| TRel => 1
| TApp fn args => S (TrmSize fn + TrmsSize args)
end
with TrmsSize (ts:Trms) : nat :=
match ts with
| tnil => 0
| tcons u us => (TrmSize u + TrmsSize us)
end.
BUT, the definition of ptrmSize in Coq (8.5pl1) is not able to
mechanically generate a functional induction principle, while the
definition of TrmSize is able to generate a functional induction
principle.
Is there a definition of size for ptrm that can mechanically generate
a functional induction principle? (I insist on "mechanically
generate" because my real application is much bigger than this
example, and I'm interested in functions other than "size".)
I know of one way to do it: recurse over something different than the
term structure. E.g. use a "fuel" parameter:
Function ptrmSize' (n:nat) (t:ptrm) {struct n} : option nat :=
match n with
| 0 => None
| S n => match t with
| ptRel => Some 1
| ptApp fn args =>
match ptrmSize' n fn, ptrmsSize n args with
| Some x, Some y => Some (S (x + y))
| _, _ => None
end
end
end
with ptrmsSize (n:nat) (ts:list ptrm) {struct n} : option nat :=
match n with
| 0 => None
| S n => match ts with
| nil => Some 0
| cons u us =>
match ptrmSize' n u, ptrmsSize n us with
| Some x, Some y => Some (x + y)
| _, _ => None
end
end
end.
Does anyone know a cleaner way?
Thanks,
Randy
