coq-club - Re: [Coq-Club] eauto loops
  • To: coq-club AT inria.fr
  • Subject: Re: [Coq-Club] eauto loops
  • Date: Mon, 27 Jun 2016 17:14:46 +0000
  • Authentication-results: mail2-smtp-roc.national.inria.fr; spf=None smtp.pra=mattam AT mattam.org; spf=Pass smtp.mailfrom=matthieu.sozeau AT gmail.com; spf=None smtp.helo=postmaster AT mail-wm0-f41.google.com
  • Ironport-phdr: 9a23:uLo3KhctYTndFHryX7GmdjYulGMj4u6mDksu8pMizoh2WeGdxc65Zh7h7PlgxGXEQZ/co6odzbGH6+a5ACdZucvJmUtBWaQEbwUCh8QSkl5oK+++Imq/EsTXaTcnFt9JTl5v8iLzG0FUHMHjew+a+SXqvnYsExnyfTB4Ov7yUtaLyZ/mj6brotaKO1gArQH+SIs6FA+xowTVu5teqqpZAYF19CH0pGBVcf9d32JiKAHbtR/94sCt4MwrqHwI6Lpyv/JHBK79ZuEzSaFSJDUgKWE8osPx5jfZSg7aw3IATmUXnwcAOA/X4RjnFsP0uzfmv+9V3SCGIcTzC7cuVmLxvO9QVBb0hXJfZHYC+2bNh5kogQ==
Hi Vadim,
  could you give a bit more context about this? Are you calling eauto or
typeclasses eauto for example?
Best,
-- Matthieu
On Mon, Jun 27, 2016 at 5:40 PM Vadim Zaliva <vzaliva AT cmu.edu> wrote:
Hi
I am facing a situation where eauto loops in type class resolution. Log fragment:
Debug: (* debug eauto : *)
Debug: 1 depth=5
Debug: 1.1: exact CarrierAsetoid on (@Setoid CarrierA CarrierAe)
What could be causing this and how to debug? It is a bit weird, as it loops
on applying single assumption indefinitely.
Vadim
CMU ECE PhD candidate
Mobile: +1(510)220-1060
