- To: coq-club AT inria.fr
- Subject: Re: [Coq-Club] eauto loops
- Date: Tue, 28 Jun 2016 08:22:45 -0700
- Authentication-results: mail3-smtp-sop.national.inria.fr; spf=None smtp.pra=vadim.zaliva AT west.cmu.edu; spf=Pass smtp.mailfrom=vadim.zaliva AT west.cmu.edu; spf=None smtp.helo=postmaster AT mail-wm0-f54.google.com
- Ironport-phdr: 9a23:nvykYhR3qaB4zXGxJ4RGabkxW9psv+yvbD5Q0YIujvd0So/mwa64ZhGN2/xhgRfzUJnB7Loc0qyN4vimADdLsc/JmUtBWaQEbwUCh8QSkl5oK+++Imq/EsTXaTcnFt9JTl5v8iLzG0FUHMHjew+a+SXqvnYsExnyfTB4Ov7yUtaLyZ/mj6broNaDOk1hv3mUWftKNhK4rAHc5IE9oLBJDeIP8CbPuWZCYO9MxGlldhq5lhf44dqsrtY4q3wD86Fpy8kVWqLjOq88ULZwDTI8Mmlz6te4mwPESF6x73cdVy0kmx5JHQGNuA/oV5PwrCLSve9gniSWIJulHvgPRT2+4vIzG1fTgyAdOmth/Q==
On Tue, Jun 28, 2016 at 12:57 AM, Matthieu Sozeau <mattam AT mattam.org> wrote:
no, they are different currently, typeclasses eauto has the ability to backtrack more on dependent goals, i.e. goalsthat depend on each other. I'd be curious to understand how you got the trace above though!Best regards,
Matthieu,
I already changed my code they way this message is gone and I could not easily to get back the old version. However if it occurs again I will let you know.
I think the problem was in a cyclic hints. Something like A->B and B->A. One of them was class constructor and another was external hint I've introduced.
CMU ECE PhD candidate
Mobile: +1(510)220-1060
- [Coq-Club] eauto loops, Vadim Zaliva, 06/27/2016
- Re: [Coq-Club] eauto loops, Matthieu Sozeau, 06/27/2016
- Re: [Coq-Club] eauto loops, Vadim Zaliva, 06/28/2016
- Re: [Coq-Club] eauto loops, Matthieu Sozeau, 06/28/2016
