coq-club - Re: [Coq-Club] How does Int31 "underlying mechanism for hardware-efficient computations" work?
  • To: coq-club AT inria.fr
  • Subject: Re: [Coq-Club] How does Int31 "underlying mechanism for hardware-efficient computations" work?
  • Date: Wed, 29 Jun 2016 20:29:12 +0200
On 06/29/2016 11:45 AM, Soegtrop, Michael wrote:
Dear Arnaud,
thanks a lot for the detailed explanation – the “Register” process
doesn’t seem to be documented in the reference manual, so this is very
welcome.
I would say the trust base increase is not that much of a problem, as
long as this can be switched off easily. I don’t see how this would be
done in the current implementation of Int32 (other than copying the
library and removing the register keyword). I would use such features
mostly for interactive development and use the plain Coq implementation
in overnight check runs, where speed doesn’t matter that much.
Hi,
The first version of the Big library as described in
A Purely Functional Library for Modular Arithmetic and Its Application to Certifying Large Prime Numbers. IJCAR 2006.
was using what you propose. A type with 2^n constructions such that the basic operations where encoded by direct pattern matching.
My memory was the biggest n Coq could handle was n = 8.
Then thanks to Arnaud we use the native int31 but I agree with you
it would be good to give the possibility to switch to a "safe" mode.
Laurent
We were using
Btw.: has it been tried to use e.g. hex digit representations in Coq?
This thesis analyses the speed up of multi-bit digit arithmetic in HOL:
FORMAL COMPUTATIONS AND METHODS by Alexey Solovyev, Pittsburgh, 2007
http://d-scholarship.pitt.edu/16721/7/SolovyevThesis_(v._1.02).pdf
For 5 decimal digit numbers the speed up is about 2.5, from 10 decimal
digits on one gets a speed increase of about 4 times for 4 bit digits.
Best regards,
Michael
Intel Deutschland GmbH
Registered Address: Am Campeon 10-12, 85579 Neubiberg, Germany
Tel: +49 89 99 8853-0, www.intel.de
Managing Directors: Christin Eisenschmid, Christian Lamprechter
Chairperson of the Supervisory Board: Nicole Lau
Registered Office: Munich
Commercial Register: Amtsgericht Muenchen HRB 186928
