Re: [Coq-Club] How does Int31 "underlying mechanism for hardware-efficient computations" work?
- From: Arnaud Spiwack <aspiwack AT lix.polytechnique.fr>
- To: Coq Club <coq-club AT inria.fr>
- Subject: Re: [Coq-Club] How does Int31 "underlying mechanism for hardware-efficient computations" work?
- Date: Wed, 29 Jun 2016 21:34:18 +0200
- Authentication-results: mail3-smtp-sop.national.inria.fr; spf=None smtp.pra=arnaud.spiwack AT gmail.com; spf=Pass smtp.mailfrom=arnaud.spiwack AT gmail.com; spf=None smtp.helo=postmaster AT mail-vk0-f50.google.com
- Ironport-phdr: 9a23:LdeSNxP8lwu64LY9KQQl6mtUPXoX/o7sNwtQ0KIMzox0KPv9rarrMEGX3/hxlliBBdydsKMczbOL+Pm7BCQp2tWoiDg6aptCVhsI2409vjcLJ4q7M3D9N+PgdCcgHc5PBxdP9nC/NlVJSo6lPwWB6kO74TNaIBjjLw09fr2zQd+KyZ3qnLnpptX6WEZhvHKFe7R8LRG7/036l/I9ps9cEJs30QbDuXBSeu5blitCLFOXmAvgtI/rpMYwuwwZgf8q9tZBXKPmZOx4COUAVHV1e1wysebsrFHoSRaFri8XVXxTmR5VCSDE6gv7V9H/qH2pmPB63XyzJ8v/ULx8Yiyj8K5gS1e8gTwfNiEw+2L/js1gyrpcpAO9qhd/xY/NfYzTOuAoLfCVRs8TWWcUBpUZbCdGGI7pKtJXV+c=
It used n=8 indeed. To elaborate (though Laurent could speak of it much better than I could), it was represented as a 256-constructor enumerated types. Since in the VM (and now native compilation) constant constructors are represented as unboxed words, this was fairly efficient (though on a 32-bit machine roughly a fourth of the real estate in each word was wasted). In fact, combined with using a tree representation rather than a list representation, this blew binary numbers (like Coq’s N
and Z
) out of the water. Because of how Coq’s pattern-matching, the size of the file defining arithmetic n the digits (which was mercifully generated) was roughly quadratic in 2^n. I had made back of the envelope calculations and estimated that using 2^16 constructors would lead to a file over 1GB long. At any rate switching to 2^31 digits (for maximal utilisation of real estate on 32-bit machines) lead to a very significant speed-up (though empirical evidences from Benjamin Grégoire suggest that it may not be the best trade-off, and using 64-bit boxed integers may work better). My most recent thoughts on the subject (though admittedly not fresh) can be found in the third chapter of my PhD dissertation [ http://assert-false.net/arnaud/papers/thesis.spiwack.pdf#chapter.3 ].
For a safe mode, I can see two ways to go. The first one is to use the external checker shipped with Coq which does not know of native integers (nor of the VM, for that matter), unfortunately, it is very likely to turn almost-instantaneous computations to computations which will not end in my lifetime (since native integers have such horrible computation property when they are not compiled specially). Another approach would be to parametrise your code to be able to switch integer implementation (one can imagine a module which, depending on options of the build system imports one of two number implementations). To facilitate that, it may be useful if the use of native integer was flagged by Print Assumptions
, though it isn’t currently.
On 06/29/2016 11:45 AM, Soegtrop, Michael wrote:
Dear Arnaud,
thanks a lot for the detailed explanation – the “Register” process
doesn’t seem to be documented in the reference manual, so this is very
welcome.
I would say the trust base increase is not that much of a problem, as
long as this can be switched off easily. I don’t see how this would be
done in the current implementation of Int32 (other than copying the
library and removing the register keyword). I would use such features
mostly for interactive development and use the plain Coq implementation
in overnight check runs, where speed doesn’t matter that much.
Hi,
The first version of the Big library as described in
A Purely Functional Library for Modular Arithmetic and Its Application to Certifying Large Prime Numbers. IJCAR 2006.
was using what you propose. A type with 2^n constructions such that the basic operations where encoded by direct pattern matching.
My memory was the biggest n Coq could handle was n = 8.
Then thanks to Arnaud we use the native int31 but I agree with you
it would be good to give the possibility to switch to a "safe" mode.
Laurent
We were using
Btw.: has it been tried to use e.g. hex digit representations in Coq?
This thesis analyses the speed up of multi-bit digit arithmetic in HOL:
FORMAL COMPUTATIONS AND METHODS by Alexey Solovyev, Pittsburgh, 2007
http://d-scholarship.pitt.edu/16721/7/SolovyevThesis_(v._1.02).pdf
For 5 decimal digit numbers the speed up is about 2.5, from 10 decimal
digits on one gets a speed increase of about 4 times for 4 bit digits.
Best regards,
Michael
Intel Deutschland GmbH
Registered Address: Am Campeon 10-12, 85579 Neubiberg, Germany
Tel: +49 89 99 8853-0, www.intel.de
Managing Directors: Christin Eisenschmid, Christian Lamprechter
Chairperson of the Supervisory Board: Nicole Lau
Registered Office: Munich
Commercial Register: Amtsgericht Muenchen HRB 186928
- [Coq-Club] How does Int31 "underlying mechanism for hardware-efficient computations" work?, Soegtrop, Michael, 06/28/2016
- RE: [Coq-Club] How does Int31 "underlying mechanism for hardware-efficient computations" work?, Soegtrop, Michael, 06/28/2016
- Re: [Coq-Club] How does Int31 "underlying mechanism for hardware-efficient computations" work?, Arnaud Spiwack, 06/28/2016
- RE: [Coq-Club] How does Int31 "underlying mechanism for hardware-efficient computations" work?, Soegtrop, Michael, 06/29/2016
- Re: [Coq-Club] How does Int31 "underlying mechanism for hardware-efficient computations" work?, Laurent Thery, 06/29/2016
- Re: [Coq-Club] How does Int31 "underlying mechanism for hardware-efficient computations" work?, Arnaud Spiwack, 06/29/2016
- RE: [Coq-Club] How does Int31 "underlying mechanism for hardware-efficient computations" work?, Soegtrop, Michael, 06/30/2016
