coq-club - Re: [Coq-Club] question about Existing Class
  • To: coq-club AT inria.fr
  • Subject: Re: [Coq-Club] question about Existing Class
  • Date: Thu, 30 Jun 2016 11:27:47 -0400
  • Authentication-results: mail2-smtp-roc.national.inria.fr; spf=None smtp.pra=jonikelee AT gmail.com; spf=Pass smtp.mailfrom=jonikelee AT gmail.com; spf=None smtp.helo=postmaster AT mail-qk0-f171.google.com
  • Ironport-phdr: 9a23:SZ7tIRSOA1jTe+EBhEBBSsQz6Npsv+yvbD5Q0YIujvd0So/mwa64ZxeN2/xhgRfzUJnB7Loc0qyN4vimADNLsc7JmUtBWaQEbwUCh8QSkl5oK+++Imq/EsTXaTcnFt9JTl5v8iLzG0FUHMHjew+a+SXqvnYsExnyfTB4Ov7yUtaLyZ/mj6brpNaDO01hv3mUWftKNhK4rAHc5IE9oLBJDeIP8CbPuWZCYO9MxGlldhq5lhf44dqsrtY4q3wD86Fpy8kVWqLjOq88ULZwDTI8Mmlz6te4mwPESF6t4X0VTmUflFJsDgnb4RfmFsPztS37ted51SSyMsj/TLRyUjOnufQ4ACT0gTsKYmZquFrcjdZ92fpW
On 06/29/2016 10:06 PM, Jonathan Leivent wrote:
On 06/29/2016 01:05 PM, Jonathan Leivent wrote:
On 06/29/2016 12:38 PM, Matthieu Sozeau wrote:
Hi Jonathan,
short answer is not currently. I would advise to make an abbreviation
class eqC instead. The fact that local hypotheses of
typeclass type are automatically considered for resolution is a feature. It
could be an option of individual class declarations
to not do that: only explicit Instances/Existing Instances for that class
would be considered. We'd certainly need to devise a
way to declare when a local binder (in fun (x : C foo) y => t) or a goal
hypothesis (e.g. after intro H) should be considered though.
Best,
-- Matthieu
Thanks, Matthieu.
What do you mean by an "abbreviation class eqC"?
Here's a guess - instead of "Existing Class eq", I tried this:
Class eqC {T}(a b : T) := equals : eq a b.
Hint Resolve equals : typeclass_instances.
with some specific Instances of eqC.
However, this seems to require the explicit use of "typeclass eauto" - a hole of eq type won't get filled automatically, unlike what was happening in the Existing Class eq case (and happening too often). I would like to have the holes corresponding to the instances of eqC automatically filled in. Is there some other way to do this?
-- Jonathan
I found an ugly workaround: use Existing Class eq, and wrap any subsequent hypothesis-like declaration that one does not want to be considered an instance, then unwrap it in a definition. This works because complete definitions are not automatically considered instances of the Existing Class - although, is that a bug? Why aren't definitions considered just declarations with proofs? Anyway, that's how it works (though none of this is in the refman or typeclassestut, or anywhere I googled) - so the workaround is:
Existing Class eq.
Variable T : Type.
Structure NonInstance X := { unwrap_noninstance : X }.
Axiom eqT_ : NonInstance (forall a b : T, a = b).
Definition eqT := unwrap_noninstance _ eqT_.
Print HintDb typeclass_instances.
(* neither eqT_ nor eqT appear:
Discriminated database
Unfoldable variable definitions: all
Unfoldable constant definitions: all
Cut: emp
For any goal ->
For Axioms, the NonInstance wrapper seems like a somewhat plausible workaround, but it is probably too ugly for section Variables or module Parameters, as one would have to wrap the corresponding actual parameters.
I think I am stuck using "Existing Class eq" if the objective is to have at least some eq holes automatically filled. I tried limiting the scope of Existing Class eq by wrapping it in a section or module - but that doesn't limit it. And "Local Existing Class" is not legal. This makes "Existing Class" a dangerous thing to use in a shared module, especially on ubiquitous types like eq.
How about this for an enhancement: allow the "Instance foo ... : T ... := ..." syntax for T even when it is not previously declared a class. Currently, this produces the error "T is not a declared type class". This would make T into an existing class in a limited capacity, so that it only accepts such explicitly declared instances.
Although I also think "Local Existing Class" is worth adding as well.
-- Jonathan
