- To: coq-club <coq-club AT inria.fr>
- Subject: Re: [Coq-Club] question about Existing Class
- Date: Thu, 30 Jun 2016 09:33:03 -0700
- Authentication-results: mail3-smtp-sop.national.inria.fr; spf=None smtp.pra=jasongross9 AT gmail.com; spf=Pass smtp.mailfrom=jasongross9 AT gmail.com; spf=None smtp.helo=postmaster AT mail-oi0-f47.google.com
- Ironport-phdr: 9a23:zFQ4OxNsJ/cAJ9cfvSEl6mtUPXoX/o7sNwtQ0KIMzox0KPj6rarrMEGX3/hxlliBBdydsKMczbOJ+PG6EUU7or+5+EgYd5JNUxJXwe43pCcHRPC/NEvgMfTxZDY7FskRHHVs/nW8LFQHUJ2mPw6anHS+4HYoFwnlMkItf6KuS9aU1pv8hrr60qaQSj0AvCC6b7J2IUf+hiTqne5Sv7FfLL0swADCuHpCdrce72ppIVWOg0S0vZ/or9YwuxhX7vkm7otLVbjwN/AzSqUdBzA7OUg04tfqvF/NV13cyGEbVzA0mwFPBUDq9hbhRd+lsCLhsexywi6BJpzeQrU9WDDk5KBuHky7wBwbPiI0pTmEwvd7i7hW9Uqs
The issue with axioms sounds like a bug. Is it present in 8.4? In any case, you should report it in the bug tracker.
[Local Existing Class] should be requested on the bug tracker with this example about variables.
Does creating a typeclass hint at level 0 that wraps all hypotheses for you work? (Does it fire before assumptions? Does it fire before assumptions if you make it a local hint extern and stick it after all the variables?)
On Thu, Jun 30, 2016, 8:28 AM Jonathan Leivent <jonikelee AT gmail.com> wrote:
On 06/29/2016 10:06 PM, Jonathan Leivent wrote:
> On 06/29/2016 01:05 PM, Jonathan Leivent wrote:
>> On 06/29/2016 12:38 PM, Matthieu Sozeau wrote:
>>> Hi Jonathan,
>>> short answer is not currently. I would advise to make an
>>> abbreviation
>>> class eqC instead. The fact that local hypotheses of
>>> typeclass type are automatically considered for resolution is a
>>> feature. It
>>> could be an option of individual class declarations
>>> to not do that: only explicit Instances/Existing Instances for that
>>> class
>>> would be considered. We'd certainly need to devise a
>>> way to declare when a local binder (in fun (x : C foo) y => t) or a
>>> goal
>>> hypothesis (e.g. after intro H) should be considered though.
>>> Best,
>>> -- Matthieu
>> Thanks, Matthieu.
>> What do you mean by an "abbreviation class eqC"?
> Here's a guess - instead of "Existing Class eq", I tried this:
> Class eqC {T}(a b : T) := equals : eq a b.
> Hint Resolve equals : typeclass_instances.
> with some specific Instances of eqC.
> However, this seems to require the explicit use of "typeclass eauto" -
> a hole of eq type won't get filled automatically, unlike what was
> happening in the Existing Class eq case (and happening too often). I
> would like to have the holes corresponding to the instances of eqC
> automatically filled in. Is there some other way to do this?
> -- Jonathan
I found an ugly workaround: use Existing Class eq, and wrap any
subsequent hypothesis-like declaration that one does not want to be
considered an instance, then unwrap it in a definition. This works
because complete definitions are not automatically considered instances
of the Existing Class - although, is that a bug? Why aren't definitions
considered just declarations with proofs? Anyway, that's how it works
(though none of this is in the refman or typeclassestut, or anywhere I
googled) - so the workaround is:
Existing Class eq.
Variable T : Type.
Structure NonInstance X := { unwrap_noninstance : X }.
Axiom eqT_ : NonInstance (forall a b : T, a = b).
Definition eqT := unwrap_noninstance _ eqT_.
Print HintDb typeclass_instances.
(* neither eqT_ nor eqT appear:
Discriminated database
Unfoldable variable definitions: all
Unfoldable constant definitions: all
Cut: emp
For any goal ->
For Axioms, the NonInstance wrapper seems like a somewhat plausible
workaround, but it is probably too ugly for section Variables or module
Parameters, as one would have to wrap the corresponding actual parameters.
I think I am stuck using "Existing Class eq" if the objective is to have
at least some eq holes automatically filled. I tried limiting the scope
of Existing Class eq by wrapping it in a section or module - but that
doesn't limit it. And "Local Existing Class" is not legal. This makes
"Existing Class" a dangerous thing to use in a shared module, especially
on ubiquitous types like eq.
How about this for an enhancement: allow the "Instance foo ... : T ...
:= ..." syntax for T even when it is not previously declared a class.
Currently, this produces the error "T is not a declared type class".
This would make T into an existing class in a limited capacity, so that
it only accepts such explicitly declared instances.
Although I also think "Local Existing Class" is worth adding as well.
-- Jonathan
- [Coq-Club] question about Existing Class, Jonathan Leivent, 06/29/2016
- Re: [Coq-Club] question about Existing Class, Jonathan Leivent, 06/29/2016
- Re: [Coq-Club] question about Existing Class, Matthieu Sozeau, 06/29/2016
- Re: [Coq-Club] question about Existing Class, Jonathan Leivent, 06/30/2016
- Re: [Coq-Club] question about Existing Class, Jason Gross, 06/30/2016
