- To: coq-club AT inria.fr
- Subject: [Coq-Club] Function problem when executing Defined
- Date: Sun, 17 Jul 2016 13:38:55 +0200
- Authentication-results: mail2-smtp-roc.national.inria.fr; spf=None smtp.pra=sorinica AT gmail.com; spf=Pass smtp.mailfrom=sorinica AT gmail.com; spf=None smtp.helo=postmaster AT mail-lf0-f50.google.com
- Ironport-phdr: 9a23:AcXdwxDC2NKt0+gNiWZ9UyQJP3N1i/DPJgcQr6AfoPdwSP78pcbcNUDSrc9gkEXOFd2CrakV06yK7Ou7CCQp2tWoiDg6aptCVhsI2409vjcLJ4q7M3D9N+PgdCcgHc5PBxdP9nC/NlVJSo6lPwWB6kO74TNaIBjjLw09fr2zQd+KyZjonLvjs7ToICxwzAKnZr1zKBjk5S7wjeIxxbVYF6Aq1xHSqWFJcekFjUlhJFaUggqurpzopM0roGxsvKcq8NcFWqHndYw5S6ZZBXIoKTMP6dXvpCXEGBCI/HoaFH4KiBNUHgzM8DnnWJbv9y/9rPB02S+Xe8PsHp4uXjH39KBxSRmgkzsdPiIk9GjLwphri7haphOqrjRwxofVZMeeM/8oLfCVRs8TWWcUBpUZbCdGGI7pN4Y=
Dear Coq-club,
I have encountered a problem when defining a recursive function on binary trees. A simplified version of the problem is given below:
Require Import Recdef.
Require Import Program.
Require Import List.
Inductive Btree : Set :=
| Epsilon : Btree
| Node : Btree -> nat -> Btree -> Btree.
Fixpoint nr_nodes (t: Btree) : nat :=
match t with
| Epsilon => 0
| Node tl n tr => S ((nr_nodes tl) + (nr_nodes tr))
end.
Require Import Omega.
Function f (t: Btree){wf (fun t1 t2: Btree => (nr_nodes t1) < ( nr_nodes t2)) t}: Btree :=
match t with
| Epsilon => Epsilon
| Node tl _ tr =>
match f tl with
| Epsilon => Epsilon
| _ =>
match f tr with
| Epsilon => Epsilon
| _ => Epsilon
end
end
end.
Proof.
intros. simpl. omega.
apply (well_founded_lt_compat Btree nr_nodes).
intros. trivial.
Defined.
When Defined is executed (the last line), Coq yields "Anomaly: Cannot create equation Lemma. Please report.". This is exactly what I am doing, i.e. reporting this problem.
Is there any way to avoid this problem or should I wait for the next release (I am using 8.5pl2 new version) ?
Thanks for any help,
Sorin
- [Coq-Club] Function problem when executing Defined, sorin stratulat, 07/17/2016
- Re: [Coq-Club] Function problem when executing Defined, Yves Bertot, 07/18/2016
- Re: [Coq-Club] Function problem when executing Defined, sorin stratulat, 07/18/2016
