- From: mukesh tiwari <mukeshtiwari.iiitm AT gmail.com>
- To: coq-club AT inria.fr
- Subject: [Coq-Club] Difference between dot and semicolon in a proof
- Date: Mon, 18 Jul 2016 11:45:30 +1000
- Authentication-results: mail2-smtp-roc.national.inria.fr; spf=None smtp.pra=mukeshtiwari.iiitm AT gmail.com; spf=Pass smtp.mailfrom=mukeshtiwari.iiitm AT gmail.com; spf=None smtp.helo=postmaster AT mail-oi0-f44.google.com
- Ironport-phdr: 9a23:R0RaZxWU5DOam6PzJMqaK2yoEhXV8LGtZVwlr6E/grcLSJyIuqrYZheOt8tkgFKBZ4jH8fUM07OQ6PG4HzBQqsrR+Fk5M7V0HycfjssXmwFySOWkMmbcaMDQUiohAc5ZX0Vk9XzoeWJcGcL5ekGA6ibqtW1aJBzzOEJPK/jvHcaK1oLshrj0p82YP1UArQH+SIs6FA+xowTVu5teqqpZAYF19CH0pGBVcf9d32JiKAHbtR/94sCt4MwrqHwI6Lpyv/JHBK79ZuEzSaFSJDUgKWE8osPx5jfZSg7a42YfX34W2gZJHAHf7VmuW4ryvzD6quti0TObe8z3TKwxcTun5qZvDhTvjXFUZHYC7GjLh5ko3+pgqxW7qkknzg==
Hi Everyone,
Pardon me if this is stupid question, but I am trying to understand the difference between dot (.) and semicolon (;) in Coq. My understanding is that we can interchange the dot and semicolon in Coq file. If you add dot after each tactic then you see the intermediate steps/calculation after applying the tactic to goal, and if you don't want to see the intermediate steps then use semicolon to combine multiple tactics. Currently I am trying to go though the coq-graph [1] code.
Lemma Union_dec :
forall (e1 e2 : U_set) (x : U),
{e1 x} + {~ e1 x} -> {e2 x} + {~ e2 x} -> Union e1 e2 x -> {e1 x} + {e2 x}.
Proof.
intros; case H.
left; trivial.
intros; case H0; intros.
right; trivial.
absurd (Union e1 e2 x). apply Not_union; trivial.
trivial.
Qed.
Lemma Union_dec :
Proof.
intros. case H.
left. trivial.
intros. case H0. intros.
right. trivial.
absurd (Union e1 e2 x). apply Not_union. trivial.
trivial.
and goal is
U : Set
e1, e2 : U_set
x : U
H : {e1 x} + {~ e1 x}
H0 : {e2 x} + {~ e2 x}
H1 : Union e1 e2 x
n : ~ e1 x
~ e2 x
subgoal 2 (ID 51) is:
Union e1 e2 x
Regards,
Mukesh Tiwari
[1] https://github.com/coq-contribs/graph-basics/blob/master/Sets.v
- [Coq-Club] Difference between dot and semicolon in a proof, mukesh tiwari, 07/18/2016
- Re: [Coq-Club] Difference between dot and semicolon in a proof, Jonathan Leivent, 07/18/2016
- Re: [Coq-Club] Difference between dot and semicolon in a proof, Benjamin Werner, 07/18/2016
- Re: [Coq-Club] Difference between dot and semicolon in a proof, mukesh tiwari, 07/19/2016
