- To: coq-club AT inria.fr
- Subject: Re: [Coq-Club] Induction question
- Date: Tue, 19 Jul 2016 17:17:58 -0400
- Authentication-results: mail3-smtp-sop.national.inria.fr; spf=None smtp.pra=fco AT 42nd.ca; spf=Pass smtp.mailfrom=fco AT 42nd.ca; spf=None smtp.helo=postmaster AT mail-io0-f171.google.com
- Ironport-phdr: 9a23:2EqBKhX06Y0kAHBROsK7NguDKyXV8LGtZVwlr6E/grcLSJyIuqrYZhaOt8tkgFKBZ4jH8fUM07OQ6PG4HzFZqs/c7DgrS99lb1c9k8IYnggtUoauKHbQC7rUVRE8B9lIT1R//nu2YgB/Ecf6YEDO8DXptWZBUiv2OQc9HOnpAIma153xjLHqvcCKKFwV2HKUWvBbFF2OtwLft80b08NJC50a7V/3mEZOYPlc3mhyJFiezF7W78a0+4N/oWwL46pyv50IbaKvdKMhCLdcET4OMmYv5cStuwOQYxGI4y4ySGwQmRtTCA+NwhzgRJrwqCKy4uR23wHGZ8v6C7s9D2fxp5x3QQPl3X9UfwUy93va35R9
Thank you for your answers! They really helped.
On Tue, Jul 19, 2016 at 5:49 AM, Dominique Larchey-Wendling
<dominique.larchey-wendling AT loria.fr>
wrote:
> Dear Francisco,
> Your lemma is a particular instance of the following
> Lemma Acc_clos_refl_trans (A : Set) (R : A -> A -> Prop) s t :
> clos_refl_trans _ R s t -> Acc _ R s -> Acc _ R t.
> Proof.
> induction 1 as [ s t H | | ]; auto.
> intros H1; revert H1 t H.
> induction 1 as [ s Hs IHs ]; intros t Hst.
> constructor; apply IHs; auto.
> Qed.
> Lemma test : forall m n, Acc nat gt (m + n) -> Acc nat gt m.
> Proof.
> intros ? ?; apply Acc_clos_refl_trans.
> destruct n.
> rewrite <- plus_n_O; constructor 2.
> constructor 1; omega.
> Qed.
> Otherwise, I suggest you prove that the much stronger result
> that Acc nat gt n holds for any n ...
> Lemma Acc_any_rec : forall n m, n >= m -> Acc _ gt m.
> Proof.
> induction n ...
> Qed.
> Theorem gt_wf : forall n, Acc _ gt n.
> Proof.
> intros; apply Acc_any_rec with (1 := le_refl _).
> Qed.
> And after that, your test lemma become a no-brainer.
> Good luck,
> Dominique
> On 07/19/2016 01:19 AM, Francisco Ferreira wrote:
>> Hello everybody,
>> I defined the following data type
>> Inductive Acc (A : Set) (R : A -> A -> Prop) (t : A): Prop :=
>> inj : (forall t': A, R t t' -> Acc A R t') -> Acc A R t.
>> and I am trying to prove a lemma by induction on it. For example, it has
>> the following shape.
>> Lemma test: forall m n, Acc nat gt (m + n) -> Acc nat gt m.
>> Trying to do induction on (Acc nat gt (m + n)) leads us to an hypothesis
>> H0 : forall t' : nat, t > t' -> Acc nat gt m
>> where t has no relation with m and n.
>> Trying to use the remember tactics
>> intros.
>> remember (m + n) as t.
>> induction H.
>> leads us to an induction hypothesis
>> H0 : forall t' : nat, t > t' -> t' = m + n -> Acc nat gt m
>> but the clause t' = m + n is unsatisfiable for any t' < t.
>> How I can use induction on Acc in such a way that the induction
>> hypothesis preserves the information and is still usable?
>> Thanks,
>> Francisco
- [Coq-Club] Induction question, Francisco Ferreira, 07/19/2016
- Re: [Coq-Club] Induction question, Frédéric Besson, 07/19/2016
- Re: [Coq-Club] Induction question, Dominique Larchey-Wendling, 07/19/2016
- Re: [Coq-Club] Induction question, Francisco Ferreira, 07/19/2016
