coq-club - Re: [Coq-Club] Apply without TC inference
  • To: coq-club AT inria.fr
  • Subject: Re: [Coq-Club] Apply without TC inference
  • Date: Wed, 27 Jul 2016 09:35:52 -0400
  • Authentication-results: mail3-smtp-sop.national.inria.fr; spf=None smtp.pra=jonikelee AT gmail.com; spf=Pass smtp.mailfrom=jonikelee AT gmail.com; spf=None smtp.helo=postmaster AT mail-qk0-f178.google.com
  • Ironport-phdr: 9a23:CEZR4hWN2rKMqRvDLvliOtKc+ZrV8LGtZVwlr6E/grcLSJyIuqrYZheEt8tkgFKBZ4jH8fUM07OQ6PG4HzJdqsve+Fk5M7V0HycfjssXmwFySOWkMmbcaMDQUiohAc5ZX0Vk9XzoeWJcGcL5ekGA6ibqtW1aJBzzOEJPK/jvHcaK1oLshrj0pcCYPloArQH+SIs6FA+xowTVu5teqqpZAYF19CH0pGBVcf9d32JiKAHbtR/94sCt4MwrqHwI6Lpyv/JHBK79ZuEzSaFSJDUgKWE8osPx5jfZSg7axHwaW3kWmxwAJwXE8hz8Qt+lsCz8t+lw3CSXFcLzRLEwHz+l6vE4G1fTlC4bOmthoynsgctqgfcDrQ==
I asked about something like this recently on coqdev (subject was: simple refine vs. typeclass hole filling vs. goal number predictability), but did not get any replies. But, I didn't know about class_apply (is there a class_refine, too?).
Since class_apply exists, then in your case it may just be that what is needed is a tactical way to "@"-ify a symbol. Right now, "@silly" and "silly" act as two distinct symbols with two distinct types - and "silly" gets typeclass inference run on it as a symbol (hence why class_apply can't prevent that). One could write a tactic that takes something like "silly" and completely generalizes it before applying it - but it may generalize it more than was intended.
-- Jonathan
On 07/26/2016 06:41 PM, Robbert Krebbers wrote:
Hi,
is there a variant of apply that does not invoke type class inference on the arguments of the applied lemma, but instead turns type class constraints into shelved subgoals so that these can be solved later.
The (undocumented) tactic "class_apply" seems to be doing somewhat what I like, but not entirely: it only turns type class constraints into shelved subgoals when the applied lemma is prefixed with an @. This is insufficient when used as part of the implementation of some Ltac tactic because I do not want the users of my tactic having to prefix their lemmas with an @.
I have included an example below.
Robbert
Require Import Classes.Init.
Class C A := c : A.
Instance nat_C : C nat := 0.
Instance bool_C : C bool := true.
Lemma silly {A} `{C A} : c = c -> True.
Proof. auto. Qed.
Goal True.
apply silly. (* BAD: @eq bool (@c bool bool_C) (@c bool bool_C) *)
(* I only want TC inference to be invoked later,
for example when doing: *)
Fail apply (@eq_refl nat).
Restart.
eapply silly. (* BAD: @eq bool (@c bool bool_C) (@c bool bool_C) *)
Restart.
eapply @silly. (* BAD: @eq bool (@c bool bool_C) (@c bool bool_C) *)
Restart.
class_apply silly. (* BAD: @eq bool (@c bool bool_C) (@c bool bool_C) *)
Restart.
class_apply @silly. (* GOOD: @eq ?A (@c ?A ?H) (@c ?A ?H) *)
apply (@eq_refl nat). (* works *)
(* But can we also do it without the @ ? *)
