- To: coq-club AT inria.fr
- Subject: Re: [Coq-Club] Apply without TC inference
- Date: Wed, 27 Jul 2016 15:14:41 +0000
- Authentication-results: mail3-smtp-sop.national.inria.fr; spf=None smtp.pra=jasongross9 AT gmail.com; spf=Pass smtp.mailfrom=jasongross9 AT gmail.com; spf=None smtp.helo=postmaster AT mail-oi0-f45.google.com
- Ironport-phdr: 9a23:LInZ4hNeY65g41lciEQl6mtUPXoX/o7sNwtQ0KIMzox0KP/7rarrMEGX3/hxlliBBdydsKMczbSL+PC5EUU7or+5+EgYd5JNUxJXwe43pCcHRPC/NEvgMfTxZDY7FskRHHVs/nW8LFQHUJ2mPw6anHS+4HYoFwnlMkItf6KuS9aU0Zn8h7n60qaQSj0AvCC6b7J2IUf+hiTqne5Sv7FfLL0swADCuHpCdrce72ppIVWOg0S0vZ/or9YwuxhX7vkm7otLVbjwV6U+V71RSjo8YE4v48i+lxDYSg3HyWEbSX5exhhBGA/D4wv9RYygmiT/v+t5niKdOJulHvgPRT2+4vIzG1fTgyAdOmth/Q==
Have you tried using Tactic Notation and ident, if I recall correctly? There should be a way to interpret a symbol as a name rather than as a constr.
I think that the extra typeclass resolution is related to a bug I ran into in 8.4 a while back, where if you have an implicit argument which is an unresolable typeclass, and the argument doesn't appear in the type, and you [eapply] the lemma, then just about every subsequent tactic (reflexivity, destruct, etc, but not refine) will fail with a typeclass resolution error.
On Wed, Jul 27, 2016 at 6:52 AM Jonathan Leivent <jonikelee AT gmail.com> wrote:
On 07/26/2016 07:27 PM, Robbert Krebbers wrote:
> Something fishy seems to be going on. When writing:
> class_apply @silly; [reflexivity|]
> with:
> Lemma silly {A} `{C A} : 0 = 0 -> c = c -> True.
> Then reflexivity invokes TC inference on the shelved goal while its
> own goal 0 = 0 does not even involve the type class.
Even though class_apply is not documented, IMHO this is a bug. There
shouldn't be a way for reflexivity in the "0=0" subgoal to alter the
other subgoal.
Note that, if one replaces reflexivity by exact eq_refl, then typeclass
inference isn't induced in that other subgoal. However, apply eq_refl
does induce the inference. And class_apply @eq_refl doesn't.
-- Jonathan
> See below for an example.
> Require Import Classes.Init.
> Class C A := c : A.
> Instance nat_C : C nat := 0.
> Instance bool_C : C bool := true.
> Proof. auto. Qed.
> Goal True.
> class_apply @silly; [reflexivity|].
> (* BAD: @eq bool (@c bool bool_C) (@c bool bool_C) *)
> (* Why does reflexivity invoke TC inference? *)
> Restart.
> class_apply @silly. reflexivity.
> (* @eq ?A (@c ?A ?H) (@c ?A ?H) *)
> (* Now it no longer happens, why is class_apply @silly. reflexivity. *)
> (* any different from class_apply @silly; [reflexivity|]. *)
> On 07/27/2016 12:41 AM, Robbert Krebbers wrote:
>> Hi,
>> is there a variant of apply that does not invoke type class inference on
>> the arguments of the applied lemma, but instead turns type class
>> constraints into shelved subgoals so that these can be solved later.
>> The (undocumented) tactic "class_apply" seems to be doing somewhat what
>> I like, but not entirely: it only turns type class constraints into
>> shelved subgoals when the applied lemma is prefixed with an @. This is
>> insufficient when used as part of the implementation of some Ltac tactic
>> because I do not want the users of my tactic having to prefix their
>> lemmas with an @.
>> I have included an example below.
>> Robbert
>> Class C A := c : A.
>> Lemma silly {A} `{C A} : c = c -> True.
>> Proof. auto. Qed.
>> Goal True.
>> apply silly. (* BAD: @eq bool (@c bool bool_C) (@c bool bool_C) *)
>> (* I only want TC inference to be invoked later,
>> for example when doing: *)
>> Fail apply (@eq_refl nat).
>> Restart.
>> eapply silly. (* BAD: @eq bool (@c bool bool_C) (@c bool bool_C) *)
>> Restart.
>> eapply @silly. (* BAD: @eq bool (@c bool bool_C) (@c bool bool_C) *)
>> Restart.
>> class_apply silly. (* BAD: @eq bool (@c bool bool_C) (@c bool bool_C) *)
>> Restart.
>> class_apply @silly. (* GOOD: @eq ?A (@c ?A ?H) (@c ?A ?H) *)
>> apply (@eq_refl nat). (* works *)
>> (* But can we also do it without the @ ? *)
- [Coq-Club] Apply without TC inference, Robbert Krebbers, 07/27/2016
- Re: [Coq-Club] Apply without TC inference, Robbert Krebbers, 07/27/2016
- Re: [Coq-Club] Apply without TC inference, Jonathan Leivent, 07/27/2016
- Re: [Coq-Club] Apply without TC inference, Jason Gross, 07/27/2016
- Re: [Coq-Club] Apply without TC inference, Matthieu Sozeau, 07/27/2016
- Re: [Coq-Club] Apply without TC inference, Clément Pit--Claudel, 07/27/2016
