coq-club - Re: [Coq-Club] Can useless warnings be switched off?
  • To: coq-club AT inria.fr
  • Subject: Re: [Coq-Club] Can useless warnings be switched off?
  • Date: Wed, 3 Aug 2016 11:37:05 +0200
  • Authentication-results: mail3-smtp-sop.national.inria.fr; spf=None smtp.pra=jung AT mpi-sws.org; spf=Pass smtp.mailfrom=jung AT mpi-sws.org; spf=None smtp.helo=postmaster AT hera.mpi-klsb.mpg.de
  • Ironport-phdr: 9a23:gVMpGx2mWvmi7tD8smDT+DRfVm0co7zxezQtwd8ZsegUL/ad9pjvdHbS+e9qxAeQG96Ks7Qb2qGP6PqocFdDyK7JiGoFfp1IWk1NouQttCtkPvS4D1bmJuXhdS0wEZcKflZk+3amLRodQ56mNBXsq3G/pQQfBg/4fVIsYL+kQsiN3o/ujLr60qaQSj0AvCC6b7J2IUf+hiTqne5Sv7FfLL0swADCuHpCdrce72ppIVWOg0S0vZ/or9YwuxhX7vkm7otLVbjwV6U+V71RSjo8YE4v48i+jxDHQ0Ot+30TGjEUjxxHKw3d7VThQYy3tTH14LkukBKGNNH7GOhnEQ+p6L1mHUfl
Hi,
> Those warnings are not produced by Coq, but rather by CAMLP4/5, and
> therefore the warning mechanism is useless here.
> Warnings cannot be turned off in CAMLP4 because the relevant API has
> been missing for ages, whereas it is possible in CAMLP5 (if they appear
> in Coq otherwise it's a bug, and it may well be one in your example). In
> any case, I advise you to switch to CAMLP5 if you didn't do so already.
It seems I have both CAMLP4 and CAMLP5 installed. How can I tell which
one Coq is using? "coqc --version" only shows the ocaml version:
> $ coqc --version
> The Coq Proof Assistant, version 8.5pl2 (July 2016)
> compiled on Jul 21 2016 11:30:45 with OCaml 4.02.3
Kind regards,
Ralf
