- From: Frédéric Besson <frederic.besson AT inria.fr>
- To: "coq-club AT inria.fr Club" <coq-club AT inria.fr>
- Subject: Re: [Coq-Club] Can useless warnings be switched off?
- Date: Wed, 3 Aug 2016 12:05:41 +0200
Hi,
The output of coq -config should output all the relevant information.
Best,
Frédéric
> On 03 Aug 2016, at 11:46, Jeehoon Kang
> <jeehoon.kang AT sf.snu.ac.kr>
> wrote:
> Dear Ralf,
> I also wonder if how I can check which of camlp4 or camlp5 is used in my
> Coq binary.. But if you installed Coq via opam or from tarball, it is
> highly likely that your Coq uses camlp5. It is the default option.
> Note that you can `opam install coq.8.5.2~camlp4` to obtain the
> camlp4-based version of Coq.
> Jeehoon
> 2016-08-03 18:37 GMT+09:00 Ralf Jung
> <jung AT mpi-sws.org>:
> Hi,
> > Those warnings are not produced by Coq, but rather by CAMLP4/5, and
> > therefore the warning mechanism is useless here.
> > Warnings cannot be turned off in CAMLP4 because the relevant API has
> > been missing for ages, whereas it is possible in CAMLP5 (if they appear
> > in Coq otherwise it's a bug, and it may well be one in your example). In
> > any case, I advise you to switch to CAMLP5 if you didn't do so already.
> It seems I have both CAMLP4 and CAMLP5 installed. How can I tell which
> one Coq is using? "coqc --version" only shows the ocaml version:
> > $ coqc --version
> > The Coq Proof Assistant, version 8.5pl2 (July 2016)
> > compiled on Jul 21 2016 11:30:45 with OCaml 4.02.3
> Kind regards,
> Ralf
> Jeehoon Kang (Ph.D. student)
> Software Foundations Laboratory
> Seoul National University
- [Coq-Club] Can useless warnings be switched off?, Chris Dams, 08/01/2016
- Re: [Coq-Club] Can useless warnings be switched off?, Jason Gross, 08/01/2016
- Re: [Coq-Club] Can useless warnings be switched off?, Chris Dams, 08/02/2016
- Re: [Coq-Club] Can useless warnings be switched off?, Pierre-Marie Pédrot, 08/03/2016
- Re: [Coq-Club] Can useless warnings be switched off?, Ralf Jung, 08/03/2016
- Re: [Coq-Club] Can useless warnings be switched off?, Jeehoon Kang, 08/03/2016
- RE: [Coq-Club] Can useless warnings be switched off?, Soegtrop, Michael, 08/03/2016
- Re: [Coq-Club] Can useless warnings be switched off?, Matej Kosik, 08/03/2016
- Re: [Coq-Club] Can useless warnings be switched off?, Frédéric Besson, 08/03/2016
- Re: [Coq-Club] Can useless warnings be switched off?, Ralf Jung, 08/04/2016
- Re: [Coq-Club] Can useless warnings be switched off?, Chris Dams, 08/18/2016
