- From: Daniel de Rauglaudre <daniel.de_rauglaudre AT inria.fr>
- To: coq-club AT inria.fr
- Subject: Re: [Coq-Club] how to proof in Z modulo?
- Date: Tue, 9 Aug 2016 16:34:26 +0200
Thanks for all your ideas. I eventually find a solution that I like.
> (x mod 3)%Z =
> (((x mod 3 - - x mod 3) mod 3 - (- x mod 3 - x mod 3) mod 3) mod 3)%Z
My solution
(* eliminating the "(-n) mod 3" *)
destruct (Z.eq_dec (n mod 3) 0) as [Hx| Hx].
rewrite Hx.
apply Zdiv.Z_mod_zero_opp_full in Hx; rewrite Hx; reflexivity.
rewrite Zdiv.Z_mod_nz_opp_full; [ | assumption ].
(* now, there are only "n mod 3" as variable *)
rewrite <- Z.mod_mod at 1; [ | intros; discriminate ].
(* beginning of the trick *)
rewrite <- Z.mod_add with (b := (n mod 3)%Z); [ | intros; discriminate ].
rewrite <- Z.mod_add with (b := (-2)%Z); [ | intros; discriminate ].
f_equal; ring.
It ends with a "ring", what I wanted to do.
I prepare it by adding what is required inside the first "mod 3" using
Z.mod_add to make the two expressions equal.
When I have this kind of equality to prove and the expressions are
complicated, I can do a "f_equal; ring_simplify" before the Z.mod_add
to see what has to be added.
http://pauillac.inria.fr/~ddr/
- Re: [Coq-Club] how to proof in Z modulo?, (continued)
- Re: [Coq-Club] how to proof in Z modulo?, Laurent Thery, 08/09/2016
- Re: [Coq-Club] how to proof in Z modulo?, Gaetan Gilbert, 08/09/2016
- RE: [Coq-Club] how to proof in Z modulo?, Soegtrop, Michael, 08/09/2016
