RE: [Coq-Club] The file ident.vo contains library dirpath and not library dirpath’
- From: "Soegtrop, Michael" <michael.soegtrop AT intel.com>
- To: "coq-club AT inria.fr" <coq-club AT inria.fr>
- Subject: RE: [Coq-Club] The file ident.vo contains library dirpath and not library dirpath’
- Date: Tue, 23 Aug 2016 10:19:29 +0000
- Accept-language: de-DE, en-US
- Authentication-results: mail3-smtp-sop.national.inria.fr; spf=None smtp.pra=michael.soegtrop AT intel.com; spf=Pass smtp.mailfrom=michael.soegtrop AT intel.com; spf=None smtp.helo=postmaster AT mga09.intel.com
- Ironport-phdr: 9a23:2sy3GBRNr8FiOHuzzfh1F/V+ftpsv+yvbD5Q0YIujvd0So/mwa64bB2N2/xhgRfzUJnB7Loc0qyN4vmmAjBLu8zJ8ChbNscdD1ld0YRetjdjKfbNMVf8Iv/uYn5yN+V5f3ghwUuGN1NIEt31fVzYry76xzcTHhLiKVg9fbytScbshsi6n9q/54fUK10RwmHsOPUpcF7s902R7pBQ2to6bP5pi1PgmThhQ6xu32RmJFaezV7Xx/yb29pdyRlWoO8r7MVaUK/3LOwSRL1cCyk6YShuvJW4/UqLcQzarHAbSyAdlgdCKwnD9hDzGJnr+GOuve1knSKeIMfeTLYuWD3k4b09GzHyjyJSfQU+/W7LkMtoyOp+oRmhrhF7icaAZYCeNPNzeuXGet4VWXBGRu5QUTBMBsW3aI5ZXLlJBvpRs4So/whGlhC5HwT5XO4=
as far as I remember, there are 8.4 patch versions of Coq which are happy with ‘ –Q “.” Top ‘ and others which insert an extra Top in the module name if you give this option (leave it away or give –Q “.” “” instead)
A few notes on this which might help:
- The relation between Coq module paths and file system paths is controlled using the –Q and –R options. How this exactly works (especially how this influences the module path written into a .vo file) is not very well documented.
- some Coq 8.4 versions contain bugs in the –Q option, See bug reports
https://coq.inria.fr/bugs/show_bug.cgi?id=3995 https://coq.inria.fr/bugs/show_bug.cgi?id=3958
Fixing this bug obviously changed the behavior of –Q and some things which did work before because the bug was there might stop working in Coq versions where the bug is fixed (and the other way around).
- As far as I can guess from my experience the Coq module name stored in a Coq vo file always contains a “Top” as root which is stripped away. So when Coq says your module is named “Top.X” it might be that it is actually “Top.Top.X”
Best regards,
Michael Intel Deutschland GmbH |
- [Coq-Club] The file ident.vo contains library dirpath and not library dirpath’, Chris Brinkley, 08/23/2016
- RE: [Coq-Club] The file ident.vo contains library dirpath and not library dirpath’, Soegtrop, Michael, 08/23/2016
- Re: [Coq-Club] The file ident.vo contains library dirpath and not library dirpath’, Randy Pollack, 08/23/2016
- Re: [Coq-Club] The file ident.vo contains library dirpath and not library dirpath’, Benjamin C. Pierce, 08/23/2016
- RE: [Coq-Club] The file ident.vo contains library dirpath and not library dirpath’, Chris Brinkley, 08/23/2016
- Re: [Coq-Club] The file ident.vo contains library dirpath and not library dirpath’, Hengchu Zhang, 08/23/2016
- RE: [Coq-Club] The file ident.vo contains library dirpath and not library dirpath’, Chris Brinkley, 08/24/2016
